Power lock kit from LMC
Have any of you tried installing this? I picked up the 2 door one. It comes with some blocks that you are suppose to attach one end to the steel push rod and the other end to the door knob rod, but the door knob rod is too thick. It would work pretty slick if they matched up, but they don't!
PooP
![]() Join Date: Sep 2008
Re: Power lock kit from LMC
i installed the 2 door one and i had to file down the block to get the rod to fit, it is soft metal so it files easy.
Oh,power door locks.I see power lock and I think "Power-Loc",GM`s posi unit.I guess my mind`s more rear end oriented.
Well, it looks like I got one of the blocks filed down just fine. The other though, I kind of messed it up and now the tiny screw won't catch, it just spins in place so I'll call LMC see about getting another one. Do you have any pictures as to how you wired it fromt he door into your cab? I've got an idea but am not positive how it will work.
#5 | |
#6 | |
With no reference and only pictures of 6x9s to go buy I ran it through the bottom half of the door with the door on it's hinges...my thought process was to run the wire up in between the inner fenders and outer fenders into the top most part of the kick panel parallel with the middle of the dash. But, my drill bit wouldn't go through, as I am not sure if there is two pieces of metal back to back in that spot. |
#7 | |
I'll take pics tomorrow you'll just need a long drill bit |
Sure do. That's where I was gonna do it at first, just didn't know if it would create any fuss with the air vent. Did you run a loom and grommets? I've been told this would be a smart idea, but I know nothing about them. Thanks for your responses...good to know I'm not in it alone!
#9 | |
Say, You said you drilled right near the vent door handle..that would mean you basically had to go through two layers of metal as it's not one solid piece correct? I took my doors off so I should have better access to it all, just wanted to not drill a hole and regret it!
#11 | |
The kits from LMC are real cheap kits. Their are a lot better and more dependable ones on the market. Usually the ones from LMC have crappy instructions to boot. You can spend a little more and get a much better product. Some of the stuff they sell is good but this is not one of them. Just my opinion
#13 | |
I bought mine from www.electric-life.com It was a 2 dr. set = #95110 NEW 2-DOOR MES CABLE OPERATED POWER DOOR LOCK KIT WITH 4-CHANNEL KEYLESS ENTRY. $163
I haven't installed them yet But at least that is one site to check. I also got the power window set at the same time. Howard
1967 C10 LWB, painted 2010 MUSTANG GRABBER BLUE & finally got it on the road after sitting in garage for 10+ yrs. Howard in MI. Last edited by howard_m18; 08-19-2009 at 07:14 PM. |
#15 |
Well, I took a shot in the dark and figured if it was junk I could just learn from it. But, I think so far, with the cheap instructions it's not going too bad. It's good for me, as I've gotta kind of think for myself. Yes, I would love something to tell me step by step how to do it, as it would relieve stress, but now that I've got the wire loom and grommets in place it looks really good, and feels better knowing I did it on my own. I'll post some pics up of here soon! I will probably next time go with a better kit, or if this one doesn't boot up return it and try something else.
#16 | |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#17 |
Here's what I did with the wires. Only bad thing is you cant operate the windows or locks with the door open. I got my locks from LMC and didn't have a problem with them.
69 Chevy 4x4 383 Power ![]() |
#18 |
So, it's been slow going as I'm not to familiar with working on cars, drilling holes, running wires and now hooking them up. I've got the actuators wired up, and ready to hook up the ground and power wire. Any opinions on where I can connect my 12v wire so that it's constantly supplied with power, also a good spot for a ground wire to connect to? Preferably one that's already got a screw to wedge it between? Thanks!
#19 |
I know this is an old thread but need some help. My dad bought the LMC kit before he passed away . I understand everything except the yellow wires that are on a plug that connects to channel one. Does anyone know what these are for, nothing in the directions for them.
#20 |
![]() Join Date: Oct 2009
For those reading the thread for the first time - as stated above, there are other vendors besides LMC. Don't forget to check out the site vendors. VH Coachworks sells a nice kit for this. http://67-72chevytrucks.com/vboard/s...d.php?t=537720
#21 |
I know from reading this that there are better kits but I already have this one and would like to use it. Any help would be greatly appreciated. For those that have not read my previous post, this truck was my dad's dream to finish. I am using what my dad purchased before he passed away. This truck has been in our family 37 years. Just trying to get it back together.
#22 | |
#23 |
Not going so bad wiring is about done. Taking it slow with 2 new doors and no hardware in them, thats next. I do have another question. My dad ordered an Autoloc flat power window kit that seems easy enough except that the motors do not come off the track. According to their instructions the motor can be moved and mounted anywhere as long as there are no kinks. I have seen other kits that look like this but you have to cut the track to fit. Any thoughts. I looked everywhere on the net but cannot find this setup. Pictures attached.
#24 |
#25 |
Hi dads1967dream - you and I are attempting the same at nearly the same time. I ordered the LMC kit about a month ago for my '72 Burban, but I haven't have the time to install it yet. Partially due to higher priority projects, and a concern that the quality of the unit may not be great. The price was probably a good indicator, but once received, confirmed. One of my door locks is really difficult to open unless the exterior door handle is leaned against - so I think the actuator will bind up, and not have the strength to open it. So...I was thinking perhaps I needed a new latch on the door before attempting and burning up the electronics.
I'd like to hear of your experience with it. Best, IriereggaeMan |
