Old 05-24-2019, 07:51 PM   #1
littlehopper
68 fuel sending unit issue, need info
Fuel gauge never worked since I bought my C20 about 3 years ago. It took running out of gas 3 times to push enough to deal with it. Well that and a tank full of sediment clogging my fuel filter.
So I bought a tank at Carlisle and a sending unit from Summit(made by Keystone) Original unit has threaded stud for wire while replacement has a stud that looks like it would use a clip on connector.
Ok, I decide to try another supplier and go with the truck shop which is a Counter Part unit that also has a clip on stud.
Should it be threaded or clip on? Where can I get a clip on connector for one of the replacements?
Any help would be greatly appreciated.
Thank you, Joe
littlehopper is offline   Reply With Quote
Old 05-27-2019, 02:51 PM   #2
HO455
HO455's Avatar
Re: 68 fuel sending unit issue, need info
This is what my 67 looks like. Can you post a photo of the new one? Then we will be able to help.
RIP Bob Parks.
Old 05-27-2019, 03:54 PM   #3
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
I use a wire connector to fasten mine to the sender. One end holds the wire, the other identical end slips over the connector. I preferred the old screw-on ones, but they seem to have gone the way of the dodo.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 05-27-2019, 04:59 PM   #4
72c20customcamper
72c20customcamper's Avatar
I just did mine . Got it from parts geek. It does have the push on terminal but I took the nut off that holds the terminal and put the wire under it. Been working fine for the last few months
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 05-28-2019, 12:39 PM   #5
littlehopper
Thank you everyone for the pictures and info, I appreciate it.
I ended up doing the same thing Mark did and used the nut and limited threads on the new sender. Works great, full gauge is on the high side of the full mark when full which I can live with.
Thank you again, Joe
