Old 05-30-2019, 01:51 PM   #1
weq92f
weq92f's Avatar
air redirection/blocking material
My A/C condenser is mounted 2 to 3 inches in front of my radiator on the outside of the core support where the radiator is on the inside of the core support.
My fans draw air through the rad well enough but from there the air doesn't really get pulled through the condenser as good as I would like. There's a 2 inch gap along the top and on the driver side between condenser and core support and a 4 inch gap on the passenger side.
I've considered several types of material for covering these gaps and am currently thinking on these...
Summit racing neoprene rubber sheets: https://www.summitracing.com/tx/part...9512/overview/
This is 1/4 inch thick 12"x12" panel of rubber that I can cut. I figure I can zip-tie or even screw these onto the condenser edges and let them get sucked into place by the fans to cover the gaps with the core support.
What have you guys used for sealing up radiator/core support/condenser air channels?
Thanks,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-30-2019, 02:02 PM   #2
Barnfind46
Barnfind46's Avatar
Re: air redirection/blocking material
1/4" seems a little thick. This could work if it is flexible enough. GM uses a similar tactic to direct air flow on the newer cars and trucks. Giving the air no other option but to travel through the condenser and radiator makes for more efficient cooling. I have also used dense foam weather stripping between the condenser and radiator core with some success. Good luck!
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 05-30-2019, 02:09 PM   #3
weq92f
weq92f's Avatar
Originally Posted by Barnfind46 View Post
1/4" seems a little thick. This could work if it is flexible enough. ...
Yeah, there's also an 1/8 thickness. I'll handle them both before deciding which to use.
The Wife suggested silicone baking sheets and even gave me a couple from her Kitchen! They were not rigid enough!
Thanks,
Just looking for more ideas!
Old 06-05-2019, 06:37 PM   #4
weq92f
weq92f's Avatar
The 1/4 inch stuff is too thick. What they label 1/8 is more like about a quarter inch and is pretty good. Only did the top for now as there's no easy way to attach this to the core support and no room for power tools down low!
Here's the before pics:
-klb
Old 06-05-2019, 06:41 PM   #5
weq92f
weq92f's Avatar
Only did the top. I've also wired my fans so that I get fan #1 on when the A/C is switched on. I've also got the panels that seal core support to grill.
After...
-klb
