Old 06-07-2019, 03:43 AM   #1
bestchevyfan
What do i need ???
I have a 1987 chev truck with lites in the dash. I want to change that to gauges with a clock . What do i need and to do ????? Thanks,buddy
bestchevyfan is offline   Reply With Quote
Old 06-07-2019, 07:29 AM   #2
Re: What do i need ???
You'll need the gauges and panel assembly that holds them. You could use the current wiring, but it will have to be reconfigured at the plug at the back of the gauge. You'll need all new oil pressure and water temp sensors. If you had a donor vehicle to geth the interrior wiring harness and the dash panel with gauges from that would be good. BTW, if you are sourcing these new, it is not cheap. It could be cheaper to go with aftermarket gauges.
Palf70Step is online now   Reply With Quote
Old 06-07-2019, 08:35 AM   #3
bestchevyfan
I have ihave all but the clock.
Old 06-07-2019, 08:59 AM   #4
TKCR
TKCR's Avatar
You’ll need the clock and the wiring for the clock. You’ll also have to change your cluster lens, good time to get a new clear one. It needs to have the hole for the stem. I added a clock, when mine originally didn’t have one.
Old 06-07-2019, 09:04 AM   #5
TKCR
TKCR's Avatar
When I had the cluster out, I also took the time and cleaned up all my other gauges. Oh, and you need a new black filler panel with the extra hole in it for the clock. Can’t think of what’s it’s called. Got everything from LMC, except the clock itself.
#11 & #12
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=100
Old 06-07-2019, 10:09 AM   #6
bestchevyfan
That is the way i want mine to look like .very nice .
Old 06-07-2019, 10:22 AM   #7
TKCR
TKCR's Avatar
Thanks, I like how it turned out. Here it is all back together
