Looking to replace headers on 65. Have uncoated ugly now. Have coated on my K5 and want to go the same. Vendors don't show listing for 65 4x4. I'm sure these are long tube now,10.25 inch from end of flange to end of collector. I have no x member for engine mounts and have mini starter so ample room. Anyone know of tried and true brand, part #? Any help/input appreciated,Thanks
Re: Header choices for 65 4x4
If yours is an automatic doug thorley has headers that will work
Was wondering if you found some headers that fit.
I have a 1963 k10 that I just swapped in a 350 with manual trans Thanks. |
I have a 1963 k10 that I just swapped in a 350 with manual trans And looking for some. Thanks. |
I have Thorleys on mine. Even though its a not a SBC, they fit nice and are really well built.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
currently on my 64 k10 with the 383 sbc and stock sm420 trans, I've got these sanderson block huggers:
https://www.sandersonheaders.com/san...ab-description I've had plenty of problems with the collector flanges, and after finding they cracked after roughly 5 years, I cut them off and welded tubes downward to solve that. however there were other cracks formed all over the place... so I did the same searches on the 60-66 forum which in their faq has plenty of header choice posts... based on those posts, I settled on Hedman long tube #69090 https://www.hedman.com/product-detail/69090 *** note: I have not installed them yet .. but from previous posts, they'll work without 'too much hassle' ... which was the best endorsement I could find
1964 ![]() 383 sbc stroker under vortec heads sm420 trans / t221 tcase / corp 10 front axle / corp 12 rear axle / 3.73 gears rolling on 33x12x15 tires on 6 lug rims. ![]() |
Found these on Summit website 1966 CHEVROLET K10 PICKUP Flowtech Headers 11500FLT.
1966 frame same 1963 to 66 Going to give them a try, will let you know. |
#9 | |
I have not yet installed my new hedmans, been blindsided by suspension woes. please let us all know how it works out!
I have Doug Thorleys probably 25 years old on my k20 put on with new motor. Thick wall nickle plated.
Never leaked, never rusted, never had to retighten any bolts Great headers
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
#11 | |
I guess that's why DT's are (at least from what I've seen thus far) the most expensive headers ever... you get what you pay for... lets see a pic of these 25 year old headers!
#12 | |
Not nickle plate ( I wish) but ceramic or jet hot. Still silver. No rust.
