motor won't crank over now
I was working on my cousin 72 chevy truck ,at first it wasn't getting gas from the tank,so I pulled the gasoline off going to the tank and put a gas can to get gas,then the motor stopped cranking over.I ran news wires just like the digram that was showed on here .purple went to the starter,light purple/orange change to the yellow wire,so yellow went to dist,and the other yellow went to the other side of the starter. I put a new ignition switch in it but i am not getting any power to the purple wire going to the starter .could it be the fuse panel ? lmk thanks
Re: motor won't crank over now
check the neutral safety switch. If an auto trans, it is in park or neutral? Don't laugh, I've done it.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
well u might be right because it has a 4 speed in it now but the old links is still in there ,dammit
TY |
All about them K’s
![]() Join Date: Jun 2014
The ignition switch gets its power from the fuse block. I bet you’ve got a dirty or corroded contact in there. I dealt with this on my truck. I don’t remember the specifics but I lost my ignition switch, backup lights and a few others. My K20 is a 4 speed and doesn’t have a neutral safety switch.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
