65 c10 overdrive help
Quick question about the overdrive relay. I can't get my relay to actually operate without external power. Schematics say that power should come from the ACC on Ignition. I'm only getting 6 volts. When I bypass and run a wire from batter to relay it works and my overdrive is alive again. Thoughts? First instanct is that I have a bad ignition switch. This switch DOES crank the truck very well. Thanks for the posts.
Moderator
![]() ![]() Join Date: Aug 2011
Re: 65 c10 overdrive help
Grounds or the power wire to the relay is deteriorating ?
If I had to guess, the power wire would be the problem. There is only one wire going from the ignition switch to the overdrive relay. This is a factory original truck. Overdrive hasn't been used since Nov '76.
See what you think of this. I traced the power wire back to the fuse box. Any ideas or suggestions?
![]() ![]() ![]() Join Date: Jan 2018
Check the inline fuse and see if the contact points are rusty. It's the white tube looking thing on the green wire
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
