Old 08-12-2019, 05:44 PM   #1
BCOWANWHEELS
compression ratio MY ENGINE PIC,S.
anybody here real good at figuring out compression ratio on a 350 sbc........ I think I,am real close to race gas on my engine build............
thanks
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-12-2019, 07:46 PM   #2
franken
Re: compression ratio
First you need to figure out combustion chamber size, piston dish/dome, gasket thickness, overbore and anything I'm forgetting. No one can tell you the CR with no info.
Old 08-12-2019, 08:29 PM   #3
BCOWANWHEELS
.030 over bore, .125 dome pistons, .015 or .041 head gasket, I HAVE BOTH , 76 cc head, 0 decked............. I,AM TRYING TO GET HONEST 10-1 COMPRESSION
Old 08-13-2019, 01:11 AM   #4
BCOWANWHEELS
Knowbody
Old 08-13-2019, 08:39 AM   #5
geezer#99
geezer#99's Avatar
Oh no!
My calcs come out to 6.2 to 1.
I used this calculator.
Punch your info in and see what you get.
http://www.wallaceracing.com/cr_test2.php
Old 08-13-2019, 08:51 AM   #6
RustyBucket
RustyBucket's Avatar
http://www.csgnetwork.com/compcalc.html
will this do it? I thought some engine guy might just KNOW from memory.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 08-13-2019, 10:17 AM   #7
kwmech
need cc piston dome. .125 does'nt work unless it is 12.5 cc
Old 08-13-2019, 12:55 PM   #8
BCOWANWHEELS
I,ll get cc,s on pistons
Old 08-13-2019, 08:49 PM   #9
BCOWANWHEELS
piston info-
compression distance 1.56
head volume -3.5 cc,s
Old 08-13-2019, 09:09 PM   #10
HO455
HO455's Avatar
Is the CC number you list an average from measurements from the assembled heads or from a chart? I've found that some Chevy heads are not very close to the advertised CC's.
Are you shooting for 10:1 so you can run pump regular?
RIP Bob Parks.
Old 08-13-2019, 11:07 PM   #11
BCOWANWHEELS
10-1 is a 93 oct eng....................76CCS ARE FROM HEADS CC,D
Old 08-21-2019, 03:46 PM   #12
BCOWANWHEELS
OK, THOUGHT THERE WAS SOME REAL MECHANICS HERE BUT GUESS I WAS WRONG.
THOUGHT THIS MIGHT HELP SOMEONE..................
Bore: (diameter) in. - 4.030
Stroke: in. - 3.48
Cylinder Head Volume: cc in. - 76CC
Effective Dome Volume: -3.5 (.125 DOME)
Use (-) for Dome . cc in.
Deck Clearance: in. -0
Compressed Gasket Thickness: in. -.039
Number of Cylinders: 8 - V8
Compression Ratio : 10.01 : 1
Total Displacement (in.3) : 355.12
Total Displacement cc's : 5821.64
Old 08-21-2019, 07:03 PM   #13
geezer#99
geezer#99's Avatar
I still get 9.2 to 1 like I did at the beginning.
What do you get and which calculator did you use?
Old 08-21-2019, 09:49 PM   #14
BCOWANWHEELS
Off of summits web site
Old 08-21-2019, 10:01 PM   #15
57taskforce
All about them K’s
57taskforce's Avatar
And here I thought you knew something no one else did.
Tyler
Old 08-21-2019, 11:52 PM   #16
BCOWANWHEELS
I used several web sites to calculate. All came to 10.1 to 1....
Perfect. I,am going to cc my intake and exh ports along with combustion chambers asap. The porting i did should help flow out some.. gotta order some .039 felpro h/gaskets tomorrow. Will have pic,s soon 4 ya,ll.
Old 08-22-2019, 06:51 AM   #17
rpmerf
rpmerf's Avatar
You are calculating for dished pistons. He has domed.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 08-22-2019, 08:28 AM   #18
geezer#99
geezer#99's Avatar
No I didn’t!
I assumed his numbers were correct but it seems he hasn’t cc’d the heads yet!
I might be closer than he thinks!
Old 08-22-2019, 11:31 AM   #19
BCOWANWHEELS
guys my heads are 441,s and there 76 cc,s. there cut .010 but I unshrouded the 2.02 intake valves slightly to increase flow.
Old 08-28-2019, 09:04 PM   #20
BCOWANWHEELS
Cc,d my chambers, all was 75 to 77 cc,s. So 9.97 up to 10.19 compression with my combo. Perfect
Old 08-28-2019, 09:19 PM   #21
AussieinNC
Moderator
AussieinNC's Avatar
A 2 cc variance in chamber volume is just ok for street use...
I like to keep them below 0.5....
Your compression ratio is around 10 to 1...too high for the gruel served up at most gas stations....try premium and add octane booster....
and watch the timing lead....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 08-28-2019, 10:43 PM   #22
BCOWANWHEELS
It will be fine for 93 real gas, no alky. I,AM NOT BUILDING A RACE ENGINE
Old 08-29-2019, 09:09 PM   #23
toolboxchev
Hey BC,
I like what your doing with your build, this is going to help you tremendously.
Check any info you may need here:
https://www.crankshaftcoalition.com/...ategory:Engine
I have flat tops in my stock engine with 76 cc heads. I can dial so much advance into it, most would call me ridiculous. With the domed pistons you will be into different territory.
The one thing that concerns me is you have as much as 2 cc of differences in each chamber. My instinct does not like that with a higher compression engine. Keep in my your dynamic compression is what will dictate true running compression with the cam selection you make.
My next build I want a bottom to mid range torque monster. With that in mind for a truck engine 2 topics came up with fellow engine buddies. Volumetric Efficiency, and Camshaft effective duration. A roller cam allows for more effective duration by design with less wear and tear.
I want the most out of the motor without all the hp hype. That just tears up a motor. Will like to see how your build turns out.
toolboxchev is offline   Reply With Quote
Old 08-29-2019, 10:03 PM   #24
BCOWANWHEELS
yea, this is the last flat tappet cam 4 me. roller from now on because of the poor quality oils now.
Old 08-30-2019, 08:15 PM   #25
BCOWANWHEELS
Heres some short block pic,s. ALL ARP FASTENERS , KING ROD N MAIN BEARINGS (THE BEST GOING NOW MADE IN ISREAL ) NEW FUEL PUMP, NEW MOTOR MOUNTS , MEW 8 INCH BALANCER NEW CLOYES DOUBLE ROLLER CHAIN N GEARSl aong with a howards reproduction lt1 350/370hp cam . SHOULD HAVE THE PAN ON IT BY TOMARROW EVENNING.
