Odd holes drilled in edlbrock aluminum intake
A friend gave me an edlbrock intake manifold a while back, I was looking at it today and noticed two holes drilled in it, one about 3/8” and the other about 1/4”. I can see them looking down through the carb mount. They don’t look factory as one has slag on the edge from drilling. Any idea why someone would drill these holes? I’ll take a pic tomorrow when I go to my shop.
Posted via Mobile Device |
Re: Odd holes drilled in edlbrock aluminum intake
Extra Vac ports?
They’re inside the manifold, they would be right under the carb if it were mounted
http://smg.photobucket.com/albums/v655/aaronhero/ |
Old member
Nitrous nozzels maybe!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Right inside below the carb, not sure what the intake of an intake is called! . Pic is for reference
![]() Join Date: Jan 2003
Egr crossover, to reduce emissions
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
Could they be stock? They are both on one side and seem to drilled in a random fashion.
Probably not factory
I’m thinking of filling them with some aluminum rod, will it make a difference, I don’t have to ever smog it, building a backup engine for my boat
#11 | |
Is the intake a single plane like your reference pic or a dual plane like my link shows?
That could be the difference. |
After thinking about it, is the 1/4" one slightly forward of the 3/8"?
If the 3/8" is being used for egr function, the 1/4" would be used for PCV if being used with valve covers without a pcv
![]() Join Date: Aug 2019
Tap them and use lock tite.
#15 |
I'm still clueless on what holes you are talking about...............
#16 |
I was wrong, the holes are on either side. It is a dual plane intake. Should I bother plugging them or just leave them alone?
#17 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Good to know I'm not the only one! Apparently there are no such holes in the reference pic, which is what I was looking at.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#18 |
I’d drill them both the same size, tap them and put plugs in. Then jb weld to seal them.
That way you know you want have any leaks. |
#19 |
Geezer posted a link to a pic, mine is just like the pic. Don’t know why I was thinking the holes were on one side, might have been the beer I drank after work!
#20 |
Moderator
![]() Join Date: Jun 2017
Sounds like a cheater NOS nozzle installation....one for NOS, one for fuel....
They hide the nozzles inside the manifold.... Post a pic of the manifold...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
#21 |
![]() Look like EGR passages to me
#22 |
Looks like a modification for the choke coil. Maybe?
Zane's 71 Build |
#23 |
Moderator
EGR feed ports...
Ones in plenum, just tap them and plug them up. Put metal cover over EGR exterior port... Block off choke heat riser port if you are using an electric choke carb... ![]() ![]() ![]()
