Old 10-02-2019, 08:24 PM   #1
dmjlambert
dmjlambert's Avatar
Backing up with a tow bar
When I remove the engine from my truck, I would like to roll the truck out of the garage and power wash the engine bay. I have a list of things I want to do with the engine and the engine bay while the engine is out.
When it comes time to put the truck back into the garage, which is uphill, I was thinking of putting this tow bar on it and use my SUV to back the truck into the garage. I understand these trucks track fine when going forward. Should I expect it to be a different story and big trouble to back it up?
It is a 1969 CST/10 pickup with power steering and manual brakes.
Old 10-02-2019, 08:37 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Backing up with a tow bar
I don't know; I don't think I've ever backed up with a tow bar.
I don't think it will be too bad since it's just a one-shot deal. I imagine you will be going slow; you would be able to stop and straighten it up with the floor jack or by steering the wheels of the towed vehicle.
I have a lag bolt in the post in front of my repair stall. That allows me to pull any disabled vehicle up in the garage with the come along.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-02-2019, 08:53 PM   #3
BigBird05
I did that with mine. Not to bad as long as it is going straight back. Helps if you have a second person steering the truck while you are backing up.
BigBird05 is offline   Reply With Quote
Old 10-02-2019, 09:05 PM   #4
lutronjim
Might tie up steering wheel like the wrecker guys do if you by yourself.
lutronjim is offline   Reply With Quote
Old 10-02-2019, 10:05 PM   #5
truckster
truckster's Avatar
I would have someone behind the steering wheel making sure it tracks.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-02-2019, 10:36 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Either of the last two replies are great, if you don't have someone to help. Backing with a tow bar (or even towing forward when turning sharp corners) has to be done carefully.
~Steven
Simi Valley, CA
Old 10-02-2019, 10:54 PM   #7
dmjlambert
dmjlambert's Avatar
Are there any special considerations or problems I could have with unpowered power steering?
Old 10-02-2019, 11:32 PM   #8
davischevy
davischevy's Avatar
It shouldn't be a problem with the steering. As said earlier, you will need someone behind the wheel or tie the wheel down. I tow a Jeep behind our motorhome and if I back up far I have to do one of the above.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 10-03-2019, 12:27 AM   #9
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
It should work quite well because the tow bar is a solid connection allowing the push vehicle to become an extension of the non-motor vehicle. I'm doing the same maneuver with one of my 72's but instead of a truck with a tow bar I use a Ford 8N tractor with a 3-point boom. I have also used a snatch block anchored to the shop floor and use a winch. A positive connection on a sloped or inclined surface is probably the safest way to move that truck. If you don't have a co-pilot to help steer, a couple of ratchet straps will hold the wheel. Tow bar should work and work well, just take it slow and easy...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-03-2019, 02:18 AM   #10
HO455
HO455's Avatar
The shorter the wheelbase on your tow rig the better in this situation. I've backed up cars on tow dollies with my S10 Blazer. I would not even attempt it with my Burban.
One other note if you have power steering you need to loop the hoses or make other provisions to catch the fluid.
RIP Bob Parks.
tow bar
