Old 10-14-2019, 11:27 PM   #1
1BAD65
Front Brake Lines Through The Frame Bulkheads Needed
Back to working on the 65 C10 and getting around to installing new brake lines.
My crossmember and the upper control arms do not have any tabs or clips for the front brake lines.
I would rather and want to just run steel braided hoses from the disc brake calipers to a bulkhead connector through the frame and then hard line to the prop valve.
Can anyone please post some links to threads covering this or part #'s for the bulkheads and braided lines.
I have a 73-87 front crossmember with disc brakes, unfortunately I do not know what year truck the 73-87 crossmember is from.
I have searched using various terms but I mostly get threads were the OP is requesting brake line routing diagrams or the thread has to do with bulkheads for air lines for bagged trucks.
Your help is greatly appreciated.
THANK YOU
1BAD65 is offline   Reply With Quote
