Old 10-17-2019, 06:08 PM   #1
msg
How to get the spring in to the front suspension?
Is a spring compressor the best way in this case? Ive got a front end that I am rebuilding and I finally have the control arms in and was about to install the coil and spindle but Im having a clearance issue. Ive seen videos where the coil is placed in and a floor jack is used, but Ive got the jack stands pretty high and I dont think Ill be able to use the floor jack method. I rented a spring compressor but the tool looks like it will be too tall once installed to even get it in and removed afterwards. I saw in the manual where it shows a different tool, I guess that the safest and only way at this point? Im really nervous about having this frame jacked up any higher to get clearance. Thoughts?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
