AC Hard Lines
Some time ago I purchased the AC hard line kit from Brothers. These are the lines the connect the condenser to the drier and go under the battery tray. Unfortunately the only thing these lines fit is the plastic bag they came in.
I have seen some drawings but not enough detail to see how these lines should be bent. Does anyone have photos of these lines going from the condenser to the drier? Thanks
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
![]() Join Date: May 2010
Re: AC Hard Lines
Maybe these will help. First is a shot of the originals on my '69 (ignore the trans cooler). Second shows the new lines. Third is of attachment to the battery box.
#3 | |
Re: AC Hard Lines
That's exactly what I was looking for. I'm going to need to mod my line near the headlight because my GMC has quad headlights. Thanks again!
![]() Join Date: Jan 2010
Re: AC Hard Lines
You shouldn't have to. Mines a gmc and l
The lines Are the same |
Re: AC Hard Lines
The line from the drier interferers with the headlight bucket mount. The line has to be modified big time to fit. The lines I have are from Brothers and as usual require modification. If I don't modify the line I would have to cut out about an inch from the headlight bucket mount.
![]() Join Date: Aug 2018
Re: AC Hard Lines
Here is a gmc if it’s any help
Doug ![]() 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
Re: AC Hard Lines
Thanks. That photo helps show the angle the inlets on the drier in relation to the core support.
