Old 12-01-2019, 05:16 PM   #1
1972 C10
1972 C10's Avatar
seat belt cleaning
What's the best product to try to revive 72 Highlander white seat belts. Not horrible, but not "white" either.
64 Chevy Suburban/Carryall 4x4
72 C10 Highlander LWB
34 Chevy 5 wdo Street Rod
64 Corvette Roadster w/AC
78 TransAm WS6
78 GMC Jimmy 2WD Slammed SOLD!
1972 C10 is offline   Reply With Quote
Old 12-01-2019, 06:38 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: seat belt cleaning
Soak the parts you can in Woolite, scrub with a brush, repeat.. Rinse.
If you have grease stains, use Purple Power, rinse repeat..
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 12-01-2019, 08:35 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I pressure wash mine after performing Astro's suggestions. Gets them pretty clean.
LockDoc
Leon
Old 12-01-2019, 10:37 PM   #4
VWNate1
VWNate1's Avatar
Post seat belt cleaning
I do a lot of this because factory correct seat belts are nice and work well as well as look good .
As mentioned : Woolite, first run warm water over them in the sink and work your fingers in to release and rinse away the looser dust and sweat residue .
Then work up a tub of warm soapy Woolite and begin at one end and slowly and gently scrub them with a soft bristle brush, do one whole side end to end, flip it over and repeat .
When finished rinse well with warm water and hang up dry, you'll be well pleased at the results .
Most smaller race tracks have adverts for local places that will re web your old nasty rotted away belts that have good unrusted buckles .
This way you can make up effectively new sets with perfect buckles collected from various different colored seat belts found under the seats of junked trucks .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 12-01-2019, 10:40 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Simple green and a stiff bristle brush works great for me.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-01-2019, 10:51 PM   #6
VWNate1
VWNate1's Avatar
Post Re: seat belt cleaning
You're working with 50 year old nylon webbing, be smart and don't use stiff brushes....
-Nate
Geezer
Old 12-01-2019, 11:01 PM   #7
leddzepp
Moderator
leddzepp's Avatar
A bristle brush doesn’t cause any damage...if you really want to be smart don’t use 50 year old nylon webbing.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-01-2019, 11:17 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
That right there is the answer I was looking for. 50-year old belts can't possibly be up to the standard of new. I got rid of the old seat belts a couple of years ago. Nylon loses its stretchability after some number of years (10?) and is useless in a wreck. Something to consider.
~Steven
Simi Valley, CA
Old 12-02-2019, 08:35 AM   #9
Actually, unless there is visible wear or damage, there is no reason nylon couldn't last about forever. This might (might not, too) be true for extremely sun faded belts. But they could have half their original strength and be more than ever required. I have nylon web 1' ratchet straps I have been securing loads so tight over edges I can play a tune on that are 25-40 years old. The only time one has broken was where it got a cut in it from being tightened over a sharp edge. Simply placing a piece of cardboard on the edge prevents that. I still used that strap for years until it only had about 1/2" left. Then just for less crucial uses. These straps are rated at 1,500# @ 1" and they are not designed to be a safety device. The material and web weave in seat belts gives them a much greater load bearing rating by design.
Old 12-01-2019, 10:57 PM   #10
If someone knows a way that cleans as well but doesn't harm the tags I'm all ears. But I have great success with mixing a strong solution of Purple Power in a bucket, drop the belts in, and forget about them a day or more. Then I scrub with a regular scrub brush and power wash. I have had just a garden hose with spray nozzle work just fine. I have done dozens of belts this way to go from looking black to whatever color they are supposed to be
Old 12-02-2019, 01:32 AM   #11
68bowtie
68bowtie's Avatar
I have caused some minor fraying (if you look closely) due to using a stiff bristled brush (I use simple green also), so I ditto the soft brush comments if you are concerned about that.
Old 12-02-2019, 07:27 PM   #12
Swamp water. How about the black residue left in the bottom of the bucket?
Old 12-02-2019, 07:39 PM   #13
TwoFiftyShifter
Makes for a mighty strong cup of joe.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
