Old 01-23-2020, 12:51 AM   #1
Divine 59
BBPanel
Per your request I snipped the image of the front window dimensions from my truck
My Build Thread http://s95.photobucket.com/user/drop...?sort=3&page=1
Divine 59 is offline   Reply With Quote
Old 01-24-2020, 12:55 AM   #2
BBPanel
Re: BBPanel
Thank you
BBPanel is offline   Reply With Quote
Old 01-24-2020, 04:48 AM   #3
DransportGarage
DransportGarage's Avatar
Re: BBPanel
What does "snipped the image" mean? I would think the vertical dimensions, for instance, would just be one number (i.e., your measurement), not a pair of numbers that vary about 3/4". (Seems I have more comprehension problems as I get older...)
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 01-24-2020, 10:36 AM   #4
BBPanel
Re: BBPanel
That image was in another thread but it had a Photobucket watermark across part of it making it hard to read so I asked for one without the watermark. The two dimensions vertically are measuring from different points as noted in the cross-section key on the right. Its a little confusing at first because it looks like some of the lines are connected but they shouldn't be. These are measurements of the windshield opening, not the windshield itself.
Name:  windshield opening profile.JPG
Old 01-24-2020, 10:51 AM   #5
dsraven
Re: BBPanel
if you really wanna have eye strain check this dimension drawing, sheet 40 ish
https://www.trifive.com/55-59Assy.pdf
Old 01-24-2020, 01:34 PM   #6
DransportGarage
Re: BBPanel
Thanks for the visual explanation! I continue to have trouble fitting a Taiwanese w/s to my cab (second gasket, second windshield). As it turns out, according to the drawings shown here, it appears my cab was chopped about 3/16" at the factory. I'll be grinding the top corners of the w/s soon. As I once heard Tommy Smothers say on his show: "If it don't fit, force it!"
Bob
Old 01-24-2020, 01:58 PM   #7
BBPanel
Re: BBPanel
Here is the original thread - check post #6
http://67-72chevytrucks.com/vboard/s...30#post7706130
Old 01-24-2020, 10:29 PM   #8
Divine 59
Re: BBPanel
Glad it was helpful, I had to cut the image out of the photobucket account since I could not find the original. The dimensions from my cab are for reference. I know the history of the truck back to 1961. Its never had accident damage to the cab that would affect the windshield dimensions.
I must replace my windshield as well, so I am hoping I will not have fitment problems.
