Static Drop
Friends, I am going to installing a 2.5/4 inch drop on my 81 C10 over the Holidays and would love some pro tips before starting. here are the plans and parts i currently have:
Front: 2.5 drop spindles stock replacement coil springs New ball joints Stock replacement shocks (didnt think i needed lowering shocks due to spindle) Sway bar Should i replace the bushings in the control arms? (i have not purchased new ones yet) Rear: 2 in hangers 2 inch shackles Drop shocks or stock? (havent purchased yet) Should i replace the bushings in the leaf springs? (havent purchased yet) This will be my first time doing this so any info is helpful! Thanks!
Builds: 1962 C10 Recreating Dad's High School Truck 1981 C10 |
![]() Join Date: Sep 2019
Re: Static Drop
I am a fan of refreshing and making things 'new' whenever I get into them. That being said, I would definitely replace what was needed while you are in there.
Mike 1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop Obligatory Build Thread HERE! 1979 C20 RCLB - 350 - TH350 Auto |
Re: Static Drop
Bushings are likely toast if it's been used & not a yard queen (the last Square trucks built are 40yrs old now). inspect them & plan accordingly. Your plan for the front seems good & you're correct the shock travel won't change w/the spindle swap.
For the rear, same rules apply for the leaf bushings. I would opt for relocating the lower shock mounting point w/shock extension brackets to get a better angle on the shocks & to allow using stock spec replacement shocks vs. 'drop' shocks. When you get it aligned, the 'book' will call for +.5 Camber. Request 0 (zero) to -.5 Camber & as much Caster as they can dial in w/that new Camber set-point. The lower center of gravity & updated camber spec will be an improvement. Check the other steering parts while you're in there. The tie-rod ends, Idler, & Pitman arms need to be in good shape as well. Summit Racing offers the Moog product line & they're usually 50% less than your local parts place on the price.
#4 | |
Re: Static Drop
Re: Static Drop
See the attached pictures for the update. Almost finished...ran into every problem you could imagine from having to break my wheel locks off to couldnt get the new shock in because the gasket was big...now i am fighting bearing race. Once i finish those, i will do the sway bar and rear.
Re: Static Drop
Old shocks...
Re: Static Drop
It's coming along well! I always run into issue, its kind of expected at this point.
I assume you have the 1" brakes? The spindles look different.
Re: Static Drop
Thank you! And yes you are correct in the 1 inch spindles. I honestly bought the spindles on CL for a really good deal like 5 years ago and didnt check if they were the correct ones...but my luck paid off this time!
So how'd it end up coming out? I'm looking to do a static drop in the future and I'd like to see your results.
Re: Static Drop
Front is done, minus the sway bar i need to install. Pretty happy with the front. Honestly, will probably end up cutting a coil off the springs i installed to try to lower the front one more inch.
Rear should be done in the next week or two. i will post updates. The steering is way better with the truck lowered though. With that said, need and alignment lol
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Static Drop
1/2 coil = 1” of drop.
That’s a rule I go by. 1 full coil will get you about 2” of drop.
![]() Join Date: Jul 2000
Re: Static Drop
How much net drop did you get on the front? I installed 2.5" spindles with new Moog coil springs (the softest they had), but ended up with a net drop of around 1.5". Turns out the new springs are the same extended height, but a little stiffer than the basic OE springs. Anyway, the truck has settled another 1/2" or so since then. I think my avatar picture is before the drop.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#13 | |
Re: Static Drop
Re: Static Drop
That is good to know. Better to start small haha.
#15 |
Re: Static Drop
Wish I would have sen this sooner. I'm right up the road and have a small press for removing and replacing the bushings. I just did the rear springs and shackles this past weekend. Took about 20 minutes to r&r all 6.
Hoping to do the fronts this weekend.
Scott 1982 GMC Sierra |
