Old 02-21-2020, 06:50 AM   #1
RADustin
help installing steering column
Gents,
I'm confused on how the steering column goes in at the firewall.
The clamp is well understood, but I am assuming the rubber gasket goes in from the inside with the metal plates behind it? to sandwich the rubber against the firewall?
Then how does the carpet fit around the column?
some inside and outside pics of the column to firewall space would be real helpful! I would appreciate any guidance.
Thanks!
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
Old 02-21-2020, 07:35 AM   #2
Getter-Done
Getter-Done's Avatar
Re: help installing steering column
here is a picture from assembly manuel.
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 02-21-2020, 09:07 AM   #3
RADustin
Attachment 1984458 .
Thanks. Helps a little.
Does the manual say what size screws are used for the rubber gasket/metal plates?
Old 02-21-2020, 07:55 PM   #4
Getter-Done
I was scanning thru the forum Quick this morning.
I thought you had a 67-72 truck.
Didn't notice this was in the 73-87 section
84 Chevy K-20
