05-07-2020, 07:41 PM | #1 |
Moderator
LS1 / LS6 Specs
Hope this helps some of you out in your engine building endeavors ....
LS1/LS6 Engine Dimensions & Clearances Production = (P), Service Limit = (SL), Out-of-Round = O-o-R Run Out = RO, Inside Dia. = ID, Outside Dia. = OD CAMSHAFT: Base Circle Dia.: '97-'04 LS1 = 19.7mm / 0.776" '01 LS6 = 19.3mm / 0.760" '02 -'04 LS6 = 19.0mm / 0.748 End Play: 0.025-0.305mm / 0.001-0.012" Journal Dia.: 54.99-55.04mm / 2.164-2.166" Journal Dia. O-o-R: 0.025mm / 0.001" Intake Lobe Lift: 7.04mm / 0.277" Exhaust Lobe Lift: 7.13mm / 0.281" Roller Lifter Dia.: 17.78mm / 0.700" RO @ Intermediate Journals: 0.05mm / 0.002" Lobe Base Circle Radius: '97-'04 LS1: 19.7mm / 0.776" '01 LS6: 19.3mm / 0.760" (reduced for ^ valve lift) '02-'04 LS6: 19.0mm / 0.748 " " " " " " CONNECTING ROD: Bearing Bore Dia.: 56.505-56.525mm / 2.224-2.225" Bearing Bore O-o-R (P): 0.004mm / 0.00015" Bearing Bore O-o-R (SL): 0.008mm / 0.0003" Bearing Clearance (P): 0.015-0.063mm / 0.0006-0.00248" Bearing Clearance (SL): 0.015-0.076mm/0.0006-0.003" Bearing Width: 24mm / 0.9449" Side Clearance: 0.11-0.51mm / 0.00433-0.02" Center to Center: 154.89mm / 6.098" Piston Pin Bore Dia.: 23.97mm / 0.9436" Piston Pin Boss Width: 24mm / 0.9449" Piston Pin Press Interference:0.020-0.043mm / 0.0008-0.0017" Rod Bolts: M9 x 1" (replace with ARP/Katech if > 450HP) CRANKSHAFT: Rotation = Clockwise (looking at front of block) Bearing Clearance (P): 0.018-0.054mm / 0.0007-0.00212" Con Rod Journal Dia. (P): 53.318-53.338mm / 2.0991-2.0999" Con Rod Journal Dia. (SL): 53.308mm Min. / 2.0987" Min. Con Rod Journal Taper (P): 0.005mm / 0.0002" (Maximum for 1/2 Journal length) Con Rod Journal Taper (SL): 0.01mm Max. / 0.0004" Max. Con Rod Journal O-o-R (P): 0.005mm / 0.0002" Con Rod Journal O-o-R (SL): 0.01mm / 0.0004" Con Rod Journal Width: 48.37mm / 1.902" End Play: 0.04-0.2mm /0.0015-0.0078" Main Journal Dia. (P): 64.993-65.007mm / 2.558-2.559" Main Journal Dia. (SL): 64.993mm Min. / 2.558" Min. Main Journal O-o-R (P): 0.003mm / 0.000118" Main Journal O-o-R (SL): 0.008mm / 0.0003 Main Journal Taper (P): 0.01mm / 0.0004" Main Journal Taper (SL): 0.02mm / 0.00078" Main Journal Width: 22.99mm / 0.905" Reluctor Ring RO: 0.25mm / 0.01" (Measured @ 1.0mm/0.04" below tooth Dia.) Crank RO : 0.05mm / 0.002" (Measured at rear flange) Flywheel Bolt Base Circle: 78.99mm / 3.110" Stroke: 92mm / 3.622" Rear Seal ID: 114.99mm / 4.527" Thrust Wall RO: 0.025mm / 0.001" Thrust Wall Width (P): 26.14-26.22mm / 1.029-1.032" Thrust Wall Width (SL): 26.32 Max. / 1.036" Max. CYLINDER BORE: Bore Dia.: 99.0-99.018mm / 3.897-3.898" Bore Taper Thrust Side: 0.018mm Max. / 0.0007" Max. Bank Angle = 45 degrees Cylinder Bank Offset: 24.10mm / 0.949" CYLINDER HEAD: A356 T6 Block Deck Flatness: 0.11mm / 0.004" (within a 6" area) Block Deck Flatness: 0.22mm / 0.008" (length of head) Exhaust Manifold Deck Flatness: 0.22mm / 0.008" Intake Manifold Deck Flatness: 0.22mm / 0.008" Height: 120.2mm / 4.732" (Deck to Rocker Cover Surfaces) Valve Angle: 15 degrees Valve Guide Material = Sintered Iron (Press IN) Valve Guide Seperation: 48.6mm / 1.913" Valve Seat Angles: 30/45/60 degree blend into chamber Valve Stem Dia.: 8.001mm / 0.315" ENGINE BLOCK: A319 T5 / 107#'s Length: 519mm / 20.43" Width: 460mm / 18.11" Deck Height: 234.57-234.82mm / 9.235-9.245" Cylinder Bank Angle = 45 degrees Cylinder Bank Offset: 24.10mm / 0.949" Center Main = Crank Thrust Wall #3 Indexing = Crank CenterLine Camshaft Bearing Bore Dia.: 55.063-55.088mm / 2.168-2.169" Block Deck Flatness: 0.11mm / 0.004" (measured within 6") Block Deck Flatness: 0.22mm / 0.008" (length of Deck) Main Bearing Bore Dia. (P): 69.871-69.889mm / 2.750-2.751" Valve Lifter Bore Dia. (P):21.417-21.443 / 0.843-0.844" FUEL INJECTION: LS1 Static Flow Rate = 3.6 gal/sec. Cranking Fuel pressure = 53 to 63 psi IGNITION: Coil Output = 60mJ Sparkplug Wire length = 219mm Sparkplug Type = AC 41-931 / Beru Silverstone S1K Sparkplug gap = 1.5mm / 0.060" INTAKE MANIFOLD; Head Deck Flatness: 0.5mm / 0.02" @ gasket mating surface LS1 MAF ID = 75mm LS1 Throttle Body ID = 75mm LS6 MAF ID = 80mm LS6 Throttle Body ID = 80mm OIL PAN & FRONT/REAR COVER Alignment: Oil Pan to Rear of Block: 0.0-0.25mm / 0.0-0.01" (@ Bellhousing Surface) Front Cover: 0.0-0.5mm / 0.0-0.2" (@ Oil Pan Surface) Rear Cover: 0.0-0.5mm / 0.0-0.2" (@ Oil Pan Surface) OIL PUMP: Dia: 89.99mm / 3.543" Gear Thickness: 10.69mm / 0.421" Pressure Relief Setting (Factory): 60 psig @ 5,000 RPM PISTONS: Cast Eutectic Aluminum, +'03 have coated skirts Weight = 434 grams Piston OD: 98.964-98.982mm / 3.8962-3.8969" Piston to Bore Clearance(P): 0.018-0.054mm/0.0007-0.00212" Piston to Bore Clear. (SL): 0.018-0.054mm / 0.0007-0.00212" (Maximum) Piston Deck Height in Operation: 0.203mm / 0.008" (Above Deck Surface) Top Land Thickness: 34mm / 0.177" PISTON PINS: Pin to Piston Bore (P): 0.01-0.02mm / 0.0004-0.00078" Pin to Piston Bore (SL): 0.01-0.02mm / 0.0004-0.00078" Max. Pin Dia.: 23.997-24.0mm / 0.9447-0.9448" Pin Fit in Con Rod: 0.02-0.043mm / 0.00078-0.00169" (Interference) PISTON RINGS: Top Comp. Thickness: 1.500mm / 0.59" Top Comp. Gap Clocking: None Required Top Comp. End Gap (P): 0.23-0.38mm / 0.009-0.0149" Top Comp. End Gap (SL): 0.23-0.38mm / 0.009-0.0149" Max. Top Comp. Groove (P):0.04-0.085mm / 0.00157-0.003346" Top Comp. Groove (SL):0.04-0.085mm/0.00157-0.003346"Max. 2nd Comp. Thickness: 1.500mm / 0.59" Top Comp Gap Clocking: None Required 2nd Comp. End Gap (P): 0.44-0.64mm / 0.0173-0.0251" 2nd Comp. End gap (SL): 0.44-0.64mm / 0.0173-0.0251" Max. 2nd Comp. Groove (P): 0.04-0.08mm / 0.00157-0.003149" 2nd Comp. Groove (SL):0.04-0.08mm/0.00157-0.003149"Max. Oil Cont. Rail Thickness (2): 3.00mm / .188" (EACH) Oil Cont. Top Rail Gap Clocking: 25 degrees from Top Ring Oil Cont. 2nd Rail gap Clocking: 25 degrees from Expander Oil Cont. End Gap (P): 0.18-0.69mm / 0.007-0.0271" Oil Cont. End Gap (SL): 0.18-0.69mm / 0.007-0.0271" Max. Oil Cont. Groove (P): 0.01-0.22mm / 0.0004-0.00866" Oil Cont. Groove (SL):0.01-0.22mm / 0.0004-0.00866" Max. VALVETRAIN:Hydraulic Roller Rocker Arm Ratio = 1.70:1 Valve Lash Net Lash: No Adjustment Valve Face Angle = 45 degrees Valve Seat Angle = 46 degrees Valve Seat RO: 0.05mm / 0.002" Max. Valve Seat Width (Intake) = 1.02mm / 0.04" Valve Seat Width (Exhaust) = 1.78mm / 0.07" Valve Stem: Clearances: Intake (P): 0.025-0.066mm / 0.001-0.0026" Intake (SL): 0.093mm / 0.0037" Max. Exhaust (P): 0.025-0.066mm / 0.001-0.0026" Exhaust (SL): 0.093mm / 0.0037" Max Oil Seal Installed Height = 18.1-19.1mm / 0.712-0.752" (Measured from VS Shim toTop Edge od Seal Body) Valve Stem Dia. (P): 7.955-7.976mm / 0.313-0.314" Valve Stem Dia. (SL) 7.9mm / 0.311 Min. Valve Spring: Free Length = 52.9mm / 2.08" Pressure (Closed) = 340 N @ 45.75mm / 76# @ 1.80" Pressure (Open) = 980 N @ 33.55mm / 220# @ 1.32" Installed Height (Intake) = 45.75mm / 1.800" Installed Height (Exhaust) = 45.75mm / 1.8" Valve Guide Installed Height = 17.32mm / 0.682" (Measured from Spring Seat Surface to Top of valve Guide) Roller Lifter Dia.:17.78mm / 0.700" Valve Material: Stainless Steel, Hollow Stems, Na filled Exhaust Cams 1997-2000 0.472/0.479, 202/210 on 117 2001 LS1 .500/0.500, 198/208 on 115.5LSA 2001 LS6 0.525/0.525, 204/211 on 116 2002 LS6 0.551/0.547, 204/218 on 117.5 Bill
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
