Old 04-18-2020, 07:20 PM   #1
cerial
cerial's Avatar
Aftermarket fuel gauge OHMS
I have a 01 2500HD that is my new tow pig/winter beater.
The previous owner installed 2 pods which both have voltage gauges in them currently. The cluster one did not read correct or something they said.
I am pulling the entire junk cluster and going to run torque off a android tablet. I am going to put aftermarket oil and fuel into the pods that were used for voltage.
I want to just pull the pins off the cluster connection and run that to a fuel gauge and if possible use the oil pin to reuse as much of this harness as I can.
I am not sure which pins/wires that I will connect to the harness and more importantly I am not sure of the OHM rating that will work with the factory fuel sending unit on this truck.
Figured I would ask before I end up with a "extra" 0-90 ohm gauge.
Any help that you can provide will be appreciated.
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
