Air Cleaner Filter?
Hey Fellas-
Is there supposed to be a filter in the slot between the snorkel and the air cleaner? |
Re: Air Cleaner Filter?
yes, but it is not very necessary if checkbyour filter often enough. Then rotate once in awhile too.
Not where you taken the pic that a bug & dirt deflector and helps air flow around carb suckion. I belevie as said there was pre-filter 85-up yr's but most do not replace them they leave them off.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
