*New Door Panels Not Fitting*
I'm back on my door panels since I have a lot of time on my hands due to the Covid-19 pandemic. I bought some 1/8" Hardboard Tempered Panel at Home Depot and got one panel cut. I drilled the holes a little over-sized so the panel would float a little to line it up. Ran into a problem. The panel is hitting the door remote at the handle and the rod causing the panel to buckle a little at the top right and making the door handle not work very well. The spring now will not return the door handle back to it's default position. I checked the thickness of the original black board panel with calipers and it is 5/64". Not much difference in the 1/8" thick panel I have. I tried adding 1/8" washers behind the panel but still to tight. How did you guys remedy this issue when making your own door panels???
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 04-22-2020 at 02:09 PM. |
