Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 09-08-2020, 03:01 PM   #1
Greaserthoughts9
C10 Diffuser roll pan
The C10 Roll Pan is in!! I got the Modshop Diffuser Installed!! It looks amazing might add some fins later but wow it looks amazing and its all painted just need to do the cab now! https://www.youtube.com/watch?v=6PPqJ0CUfgA
Greaserthoughts9 is offline   Reply With Quote
Old 09-09-2020, 08:27 AM   #2
Re: C10 Diffuser roll pan
I wanted to see the rest of how you guys got that bed off. Next time you haul a bed haul it upside down. You don't risk damage to the lower bed and you gain a continuous matched surface to slide it straight off. Also, if you haul it with the front to the rear you have something to grad ahold of and two people can hold it up as the rest of the bed slides back.
Old 09-09-2020, 06:21 PM   #3
SCOTI
SCOTI's Avatar
I'll add to this for others that might need to haul a bed....
Use the 2x4's to protect the steel surfaces of each truck bed. Wrap them w/a towel for some cushion. Make the length of the 2x4's long enough that someone can use it as a handle for lifting the bed to move it. We tied the F/R 2x4's together (I----I) to keep each end from slipping forward/backwards.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
