Old 09-14-2020, 02:04 PM   #1
Bueno 68C-10
Bueno 68C-10's Avatar
K30 Axle Transplant or Frame Swap
Hey guys,
I am looking at swapping my 67 c30 over to 4x4. I am curious does anyone have experience with this? Is it better to transplant a dana 60 under my c30 frame or is it better to Get a 73-87 K30 frame and do a body swap?
Thanks in advance!
Bueno 68C-10 is offline   Reply With Quote
Old 09-14-2020, 02:15 PM   #2
kwmech
Re: K30 Axle Transplant or Frame Swap
Square body frame swap (in my opinion) would be more work than putting a front end under the existing frame. But I've been doing conversions for over 30 years. Is your 67 frame dented in at the steering box?
kwmech is online now   Reply With Quote
Old 09-14-2020, 03:13 PM   #3
Bueno 68C-10
kwmech,
Thank you for the reply! I believe my frame is not dented for the box, but I would need to look again. If it is dented, I will have to patch this with flat steel correct?
Old 09-14-2020, 03:26 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
Originally Posted by Bueno 68C-10 View Post
kwmech,
If it is dimpled for the steering box you won’t have to do anything but bolt up the later style powering steering box. I would swap the 60 under your existing frame. The square body frame can be made to work but it’s not plug and play by any means.
http://67-72chevytrucks.com/vboard/s...=703160&page=6
This thread might give you an idea about what it’ll take to get the front axle under it. There are others like it on here too.
Tyler
Old 09-14-2020, 06:00 PM   #5
gmc684x4
Are the k30 spring mounts different then say the k10
I have a chance to get a 70 c30 gmc and thinking of things to do with it
In the land of ice and snow a heavy 2 wheel drive is not as useful
gmc684x4 is offline   Reply With Quote
Old 09-14-2020, 06:54 PM   #6
57taskforce
All about them K’s
67-72 4x4 and square body K30 use the same spring perch width front and rear. 1/2 and 3/4 square body rear perches are not the same as 67-72. Square body front axle perches are the same width as 67-72 4x4. Clear as mud??
Tyler
Old 09-14-2020, 07:02 PM   #7
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I converted my C30 frame to 4x4. Its pretty simple if you can locate the 4x4 brackets.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 09-14-2020, 08:27 PM   #8
Yep. Pretty darn easy. Almost plug and play. Definitely the way to go
Old 09-15-2020, 02:03 AM   #9
gmc684x4
Did you bolt the spring perchs on with 7/16 grade 8 bolts ?
I have a line on a c30 running truck been decideing on what could do to it
A 70 gmc 1 ton dually 4x4 would be a good project for it a spare sm465 with 205 tcase a spare 69 k10 chassis 8 bolt dana 44 and dana 60 rear i guesing the rear in the c30 is a dana 60
Old 09-15-2020, 11:32 AM   #10
Bueno 68C-10
Where did you find the brackets?
Also do you have to drill the mount holes? If so does anyone have a template or measurements to follow?
Old 09-15-2020, 05:59 PM   #11
57taskforce
All about them K’s
Most guys use the front spring hanger/core support brackets from a 4x4 truck. You will have to drill the holes.
A paid subscription and a want to buy add on the parts board will likely get you what you need.
Off road design and others have fabbed front hangers that can likely be made to work but won’t be as easy as the oe offering.
Tyler
Old 09-15-2020, 10:03 PM   #12
71blksuper4x4
SWB 4x4 Collector
I have collected parts over the years or 4x4s destined for scrap. I robbed 4x4 brackets from my parts stash and drilled and bolted them to accept the next size up grade 8 bolts. This truck was originally a 72 C30 chassis.
TREVOR
Old 09-16-2020, 06:55 AM   #13
You can use spring brackets from any GM 4wd frame, from Blazer up.
Old 09-16-2020, 08:18 AM   #14
Bueno 68C-10
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Old 09-16-2020, 10:41 AM   #15
71blksuper4x4
SWB 4x4 Collector
I only have one spare set left, and I am contemplating using them on a longhorn frame I have to make a K30 Dually.
TREVOR
Old 09-16-2020, 11:02 AM   #16
Bueno 68C-10
No problem! Thank you for your input, How do you find where the back front axle mount should be located?
Old 09-17-2020, 06:41 PM   #17
Bueno 68C-10
How do you find where the rear of the front leaf spring mount should be located?
Old 09-17-2020, 09:19 PM   #18
71blksuper4x4
SWB 4x4 Collector
I measured from the radiator support bracket to where it landed on one of my 4x4 frames. I may have also measured from the front cab mount as well. The 67-72 Chevy 4x4 brackets are made to sit on the inside of the frame rails, so really, you just need to locate the bushing hole.
TREVOR
Old 09-17-2020, 09:49 PM   #19
Bueno 68C-10
That’s simple enough. Thank you!
