![]() Join Date: Sep 2018
Does a patch panel exist for here?
I cant seem to find this available so i thought id ask here, ya’ll seem to know your stuff.
![]() ![]() Join Date: May 2015
Re: Does a patch panel exist for here?
Is that the kick panel,.?
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 09-16-2020 at 08:03 PM. |
Yes except that seems to be the mirror image of the passenger side but now that i know it’s correct name i can refine my search
Posted via Mobile Device |
https://www.classicindustries.com/sh...q=Kick%20panel
The above pic is driverside Below pic is pass side
#5 | |
Thank you! |
![]() ![]() Join Date: Oct 2014
rotated
![]() Join Date: Jul 2007
Left https://www.classicparts.com/1955-59...tinfo/44-115D/
Right https://www.classicparts.com/1955-59...tinfo/44-116D/ I also found the right one on Ebay with measurements https://www.ebay.com/i/391917980606 Same Dynacorn part number for the left one on Speedway https://www.speedwaymotors.com/Dynac...%20(Mar12_2019) Here is the right one https://www.speedwaymotors.com/Dynac...vy,401342.html I'm not a big Speedway fan but that is a 100 buck total difference from the truck trinket shop prices. 173.99 ea as apposed to 224.95 From all of the classic truck parts shops who seem to always have the same prices across the board.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 09-17-2020 at 01:17 PM. |
I recommend, before you order anything, to check under the floor where the cab mounts are. if that part is rusted then the under floor parts, which weld to that, are likely gonna need some help too. the step is also connected in the bottom of the hinge pillar as well as the lower fender mount. there are a few other parts you may need. inner cowl needs to come off if doing the whole panel, for one.
here is a link to the assembly manual showing how it all goes together https://www.trifive.com/d1/55-59Assy.pdf sheet 6 and on do some good precise measurements and X brace the crap outta the cab if you plan on replacing that part. pics with measurement locations work well. when assembling tack stuff together then install the door so you know it fits before final welding. actually, make sure the door fits before you start so you have a baseline. sometimes those replacement panels have the wrong threads for the door hinges so check before installing fasteners. like same size but course instaed of fine threads. |
don't expect a aftermarket part to fit right anyway
the most common ones I could find have speakers https://www.ebay.com/itm/CHEVY-1955-....c100290.m3507
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 09-17-2020 at 04:19 PM. |
here is a pic of one of my hinge pillar repairs, from the inside looking out, pass side, it helps you understand whats inside there hopefully
#11 | |
Thank you all. Lots of helpful advice here. I have it all planned out now. I just couldn’t find that part for the life of me. Helps when you aren’t looking for “inner vent panel” lol. I didn’t know what else to call it.
Thank you very much Posted via Mobile Device |
i'd cut it out and weld in a patch before spending $300 on a patch
easy peasy ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#15 |
You can always trim offwhat part of the patch panel you dont need and weld that in.
