Old 12-13-2003, 05:00 PM   #1
charles oliver
68 camtruck
charles oliver's Avatar
Power steerig conversion 4x4 Jimmy 71
Does the 4X4 71 Jimmy need different parts to convert it to power steering than a 4x2 C10 ?
If So can anyone tell me what works and maybe does anybody have all the necessary parts, in excellent working condition of course.
I am looking at purchasing one and would like to know !
Charlie
ceoliver@fuse.net
charles oliver is offline   Reply With Quote
Old 12-13-2003, 07:04 PM   #2
LeRoy
Registered truck nut
LeRoy's Avatar
The 2wd box is different so you'll need a 4wd box and lines. The pump and brackets are the same
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 12-15-2003, 06:12 PM   #3
charles oliver
68 camtruck
Power Steering Conversion
I am going to convert a 1971 Jimmy 4x4 to Power Steering.
Could someone please tell me what parts will fit properly.
Charlie
Old 12-15-2003, 09:24 PM   #4
chiphayes
i would stay with an 73 thru 88 4x4 gearbox,be sure it still has the pitman arm on it,and get the pump and hoses. it will bolt right on with no drilling.be sure you know if you have the short or long water pump and get the stuff off the same.
chiphayes is offline   Reply With Quote
Old 12-15-2003, 10:11 PM   #5
LeRoy
LeRoy's Avatar
chiphayes is right but they changed the type of hose fittings somewhere in the 80's. It's still a bolt on though. Also you can get the box of any Sub, truck 1/2 ton-3/4 ton, Blazer whatever, they're all the same
Old 12-16-2003, 03:08 AM   #6
earl87gta
earl87gta's Avatar
I have a box off a 72 blazer I will sell you it work good I went to cross over steering and had to use the 2wd box.
Earl
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 12-16-2003, 10:54 AM   #7
Dean
Dean's Avatar
I have a parts 72 4x4 Jimmy that has everything you need on it to convert to PS plus lots of other spare parts. I'm in Cincy. Just a thought.
Dean is offline   Reply With Quote
Old 12-16-2003, 08:12 PM   #8
charles oliver
68 camtruck
72 4x4 Power Steering
Please give me a call or leave me your number.
Charlie
ceoliver@fuse.net
513-367-0737
Old 12-17-2003, 07:19 PM   #9
Huck
Huck's Avatar
Charlie, any 68 and up thru the 70's 4x4 PS setup will work. I would not buy piece parts but get a complete setup with hoses brackets pulley etc. And make sure the seller guarantees it not to leak, bind etc. It will be a direct bolt up> I had planned to convert that Jimmy to PS but never got around to it. Nice to hear it will stay in the "Family". Huck
Huck is offline   Reply With Quote
Old 12-17-2003, 07:22 PM   #10
charles oliver
68 camtruck
Power Steering 71 Jimmy
Huck, Thanks for the info. Do you know if I will have to change the Center Link or some say Drag Link? I know I had to do that on the 68 C10 when I converted it.
Charlie
