Old 12-22-2020, 03:48 AM   #1
pdxhall
pdxhall's Avatar
Roof pictures needed please
I could use a couple of roof pictures with the top off from someone that has replaced the top on their roof, please. I'm trying to find a way to run wiring for my roof lights
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 12-22-2020, 08:57 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Roof pictures needed please
I couldnt get a wire thru the a-pillar or a coat hangar wire to pull one thru. Only one way I know of. Maybe other trucks are different?
Old 12-22-2020, 11:25 AM   #3
LT1 Burb
LT1 Burb's Avatar
There is a little piece of factory insulation up there.
LT1 Burb is offline   Reply With Quote
Old 12-22-2020, 11:44 AM   #4
The Rocknrod
Moderator
Like this?
Old 12-22-2020, 12:30 PM   #5
LT1 Burb
LT1 Burb's Avatar
I would bet there is a mouse nest in 99% of these trucks.
Old 12-22-2020, 12:42 PM   #6
The Rocknrod
Moderator
No doubt.
Old 12-23-2020, 03:59 AM   #7
lilpoindexter
lilpoindexter's Avatar
Is there anything anybody is doing to attempt to keep them damn mice from getting up there again?
lilpoindexter is offline   Reply With Quote
Old 12-23-2020, 08:27 AM   #8
The Rocknrod
Moderator
Lets see - Irish Spring, Moth Balls, Dryer Sheets etc:
http://67-72chevytrucks.com/vboard/s...d.php?t=772234
http://67-72chevytrucks.com/vboard/s...d.php?t=393866
https://www.google.com/search?domain...D%3A1%3B&hl=en
Old 12-23-2020, 09:42 AM   #9
nsb29
nsb29's Avatar
By keeping the door shut and the windows up would be a pretty good deterrent
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 12-23-2020, 12:53 PM   #10
pdxhall
pdxhall's Avatar
Thanks for the photos. This is a real puzzle. I also tried the front door pillar but I found the same problem. I found an original wiring diagram for the lights and it shows the wiring going to the rear and going down the rear panel like the interior light but I'm not having much luck. Well, I'll just keep trying with my wiring snake and hope for the best.
Sanity'66
Old 12-23-2020, 12:55 PM   #11
The Rocknrod
Moderator
Run your snake thru the visor mount hole to the rear pillar. "Maybe" that will help.
Old 12-23-2020, 12:58 PM   #12
REDROCKER652002
when I put in a new dome light in my son's truck, I used a very rigid thick gauge wire and just fished it from the dome light opening down to and thru the drivers side. It was a bit of a chore but I finally got it to work
REDROCKER652002 is offline   Reply With Quote
Old 12-23-2020, 12:59 PM   #13
pdxhall
pdxhall's Avatar
Thanks but I tried that. No problem getting to the lights but no luck YET getting it to the back.
Sanity'66
Old 12-23-2020, 01:16 PM   #14
Mack B
Mack B's Avatar
I used a piece of tie wire to fish some wires from the back to the visor hole. I can’t really give you any advice other than it is possible but took some persistence. Good luck!
Mack B is offline   Reply With Quote
Old 12-23-2020, 02:35 PM   #15
53Sparky
53Sparky's Avatar
Crossover from work to hobby - as an electrician I always leave a pull line in place when we fish something complex. It's a PITA to fish this so when you successfully pull the wires through, consider leaving a piece of nylon line that won't melt or rot in there so you can pull something else through at a later date. Say you want to add a mic for your bluetooth refit so you can talk hands free. Or whatever reason I can't think of now. Maybe Mrs. PDXhall wants a vanity light on the passenger visor.
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 12-29-2020, 04:38 PM   #16
pdxhall
pdxhall's Avatar
Thanks for the input. It's good to see that it is possible. I'm going to work from the back to the front and see if I can make that work.
Sanity'66
Old 12-29-2020, 09:20 PM   #17
kaycee
kaycee's Avatar
Dont know if it will help but I put a console above my mirror in my 69 C10, it had the 2 map lights in it and a storage pocket came from a mid 90's blazer.I used a air hose and a small string and started at the sunvisor hole and gently blew air toward the A pillar and fed the string through the hole it freeking found the path down to the kickpanel where there was a hole . worked great There was a youtube video on it by a guy here on the forum tx firefighter I belive is his handle.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 12-29-2020, 09:38 PM   #18
kaycee
kaycee's Avatar
BAAAZINNGAAA
http://67-72chevytrucks.com/vboard/s...=running+wires
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 12-30-2020, 02:25 PM   #19
pdxhall
pdxhall's Avatar
Originally Posted by kaycee View Post
Thank you so much for locating this post. I will be trying this and I will post the results of my work.
Sanity'66
Old 01-05-2021, 01:15 PM   #20
OL SKOOL
OL SKOOL's Avatar
Best trick i've seen in a long time awesome. Thanks for posting and Texas firefighter for sharing.
OL SKOOL is offline   Reply With Quote
