Old 11-24-2019, 09:55 AM   #1
CJ2A
CJ2A's Avatar
Original Radiator
I was planning on using my original radiator in an LS1 swap into a 1963 GMC. I have been told the original radiator will work fine. I have also been told I need an Aluminum Horizontal core radiator.
Any personal experiences I can learn from ? Any thoughts ?
48 CJ2A
63 1500 GMC (LS1 w/ Muncie 4spd)
68 RS Camaro
71 K20 BBC & granny 4 speed
95 2500 4x4
17 HD2500 4x4
Want => 67 C10 short bed w/ Manual Tranny
CJ2A is offline   Reply With Quote
Old 12-16-2019, 02:50 PM   #2
Factory Guy
Factory Guy's Avatar
Re: Original Radiator
From what I understand you can/should use the original (if it will fit).
Factory Guy is offline   Reply With Quote
Old 01-20-2020, 12:17 PM   #3
dean jendro
Old and crusty
dean jendro's Avatar
I used this one. Installed 3 years ago with no problems.
https://www.entropyrad.com/1963-1966...-radiator.html
65 Chevy long wide daily driver - SOLD!
64 Chevy Short Step LS
dean jendro is offline   Reply With Quote
Old 01-24-2020, 10:23 AM   #4
Custom 68
Custom 68's Avatar
I used my original one for years. I did recently swap to an aluminum one. Not a real expencive one but I thought it might be better since I get into traffic during the power tour or CTC.
My original was good but the newer ones seem to flow better and I did get some better cooling. I would just run what you have and watch the temps.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 02-02-2020, 10:13 AM   #5
Thealien
Thealien's Avatar
When I did my Jimmy about 10 years ago I had a radiator shop make some changes to my stock AC radiator. He added a steam port and IIRC changed the size(s) of the hose bungs?
Worked perfectly until I sold the Jimmy.
Old 02-06-2020, 04:48 PM   #6
thehata1
I swapped an LQ4 into my 72 C25 and kept the factory radiator. I have not had any problems here in Colorado.
thehata1 is offline   Reply With Quote
Old 02-10-2020, 01:12 PM   #7
verdell
verdell's Avatar
Unfortunately, I never had the original radiator although I think it would've worked. I ended up going with a 26"x19" crossflow aluminum radiator from Northern and was able to keep the upper and lower hoses on the passenger side. Ran it to CTC back in October with new Vintage Air system and worked great.
verdell is offline   Reply With Quote
Old 03-13-2020, 05:01 PM   #8
truckdude239
truckdude239's Avatar
Moved to the ls swap forumn
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-01-2021, 06:29 PM   #9
Justin71105
Currently looking for a radiator my 64 C10 LS swap. Debating buying a specific swap radiator or the Champion CC284 radiator with fans that has the inlet/outlet in stock positions and sized 1.5/1.75.
Found adapters for hose size on ICT's website but got to add up cost and see how much the fittings and 4 hoses is going to add up to vs buying a specific LS radiator.
Found the CC284 on AZ Pro website offered in LS swap already, its around $550 with fans and shroud. Waiting for them to email me back about the radiator.
1964 C10 Rusto-mod
5.3L - L59 Flex Fuel
Justin71105 is offline   Reply With Quote
Old 01-02-2021, 03:36 PM   #10
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
That’s exactly what I did. I wasn’t going get rid of my BB 4 core for a non repairable aluminum one when I went LS. It works perfect.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-06-2021, 09:26 PM   #11
dean jendro
Old and crusty
I have an older version of this one. Still going strong 5 years later with zero problems.
https://entropyrad.com/product/1963-...inum-radiator/
Old 01-08-2021, 12:25 PM   #12
RLC
Anyone had experience with radiators from this company: http://www.speedcooling.com. I am considering using their 1967 - 1972 Chevy truck radiator. Based on their web site it uses the original 4-row mounts, lifetime warranty, aluminum construction with a heavy duty 2-row core with 1.0" tubes, heavy duty transmission cooler, fully TIG welded construction with no epoxy.
RLC is offline   Reply With Quote
