Old 02-03-2021, 06:22 PM   #1
k-nuts
k-nuts's Avatar
Upgrade to Crate engine HP?
1970 Jimmy 4x4 2.5” all spring lift 33” tires. New thread, since different question.
The turn key zz6 405hp GM crate motor is at my top end of my engine upgrade budget. But is that too much HP for stock driveline??? I would have 350trans rebuilt to handle. Have Stock 205 xfer. Stock axles and driveshafts. Haven’t verified gear ratios and if the spid mentioned “posi” is still in there. At a minimum new joints/shaft.
Not planning on any crazy muddying, rock crawling or racing. But also don’t want to be sitting on the grenade scared to push the pedal ��
Also Not wanting to chase parts for axle swaps, LS conversions, etc. Looking to put crate engine rebuilt trans and drive.
Reason for zz6 was the heads and being roller cam & lifters and of course the extra HP I know I could save $ possibly having something built or getting a different engine and changing cam etc but I don’t have a relationship with a machine shop. And like the warranty on the GM crates.
Free time is what’s limited.
k-nuts is offline   Reply With Quote
Old 02-03-2021, 08:11 PM   #2
SeventyOne
Re: Upgrade to Crate engine HP?
An upgraded trans would be all you need. NP205 is bulletproof. 12bolt rear axles are solid as well. Your Dana 44 front axle shafts are likely the weak link in 4wd but ought to handle the 33" tires.
SeventyOne is offline   Reply With Quote
Old 02-03-2021, 09:08 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
What’s the present gear ratio? 3.73 might work well with the combo.
Old 02-03-2021, 09:53 PM   #4
k-nuts
k-nuts's Avatar
Thanks. That was What was I hoping. I ran 39’s on my 1990 K5 back in the day. All stock drivetrain except auburn unit and 5.13’s. Wasn’t advisable, but I was i was on a student budget. Pretty sure they were 8.5” 10 bolts.
Not sure, I need to check! Thanks
Old 02-04-2021, 01:28 AM   #5
Sand Wrench
Sand Wrench's Avatar
You might consider the HT383 as well, it will make better torque in the lower RPM ranges. You'll have to wrap that ZZ6 up to 5000-6000 RPM to really take advantage of all that power.
You ever have one of those mornings where you wake up owning more trucks than you did the night before?
1972 K5
1972 K10
1967 K20 bucket truck
Sand Wrench is offline   Reply With Quote
Old 02-04-2021, 11:33 AM   #6
hemi43
hemi43's Avatar
Make sure to budget for EFI. Carbs are good for wheel chocks, IMO.
hemi43 is offline   Reply With Quote
