Old 01-26-2021, 02:40 PM   #1
easyrider
easyrider's Avatar
Side fender emblem mount
I ended up replacing my front fenders with after market fenders and after installing fenders/ inner fender I noticed there wasn't any holes in the fenders for the C-10 bowtie and upon further inspection after fender installed, there is no access to back of fenders to put nuts on emblem if there were holes to install emblems !
So, I really don't want to take fenders and inner fenders back off. It was a bugger getting holes to line up in the process.
I remember on one car I had the emblems were held on with metal inserts that fit into hole and emblems push fit into them. I can't remember what car they were on though.
Any ideas what would be easiest way to make this work out? I'm sure this isn't the only time someone had this happen. I do want my side emblems on fenders.
Any help or information will be greatly appreciated....Thanks!!
easyrider is offline   Reply With Quote
Old 01-26-2021, 02:46 PM   #2
A1971Blazer
A1971Blazer's Avatar
Re: Side fender emblem mount
Barrel clips
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 01-26-2021, 02:46 PM   #3
Davidf
You are looking for "barrel clips". Search around and you will find them as I cannot remember the size needed, but 3/16" (1/4" hole) comes to mind. These same clips are used (or can be used) to hold the tailgate latch rods to the release handle mechanism.
Davidf is offline   Reply With Quote
Old 01-26-2021, 03:04 PM   #4
easyrider
easyrider's Avatar
that is exactly what I was looking for! Thanks guys!!
Old 01-26-2021, 03:09 PM   #5
easyrider
easyrider's Avatar
While I'm picking your brain; this might be even harder, but when I bought a after market hood I noticed it didn't have any holes for the CHEVROLET letters, I was told that none of the after market hoods had these holes. I had resigned myself to not using the letters on hood, but if there was a way to mark where exactly those holes would be I might like to reconsider. Any ideas or help will be
a great help. Thanks again!!
Old 01-26-2021, 03:30 PM   #6
FirstOwner69
FirstOwner69's Avatar
Chevrolet hood letter template may be available for rental here (see post 25):
https://67-72chevytrucks.com/vboard/...d.php?t=776235
Jim
FirstOwner69 is offline   Reply With Quote
Old 01-26-2021, 03:41 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Here are a couple of threads on the subject.
http://67-72chevytrucks.com/vboard/s...d.php?t=741019
http://67-72chevytrucks.com/vboard/s...d.php?t=776235
Souds like you should get a hold of member Getter-Done (second link)
Edit: Looks like FirsOwner69 beat me to it while I was looking stuff up....
LockDoc
Leon
Old 01-26-2021, 04:06 PM   #8
easyrider
easyrider's Avatar
thanks guys!!
