Old 02-08-2021, 11:44 PM   #1
66C10LB
Outer skin flange to door frame repair methods
Interested in other peoples methods to clean up rust and pitting under flange. After much indecision, I have come up with this- Cut off the flange of the outer skin leaving about 1/8 inch at the bend so as not to disturb the outer skin. Grind down the rust and pitting on the now exposed door frame until about 90% of the pitting is eliminated. (I noticed that the door frame is about 14g so I think it is OK to loose a bit of this thickness). For the remaining few pits, drill them out and spot weld those spots. Grind smooth. Cut a very narrow strip of 18g and weld along the join (tack and fill) thus creating the replacement flange. (Copper rich weld through primer between the layers)
66C10LB is offline   Reply With Quote
