Old 03-23-2021, 06:30 PM   #1
royr
Removing Jimmy Emblem.
Any tricks to removing the emblems without having to unbolt outer/inner fenders? Thanks
royr is offline   Reply With Quote
Old 03-25-2021, 07:31 PM   #2
truckster
truckster's Avatar
Re: Removing Jimmy Emblem.
I'll jump in here since you haven't received any responses yet. Having just put my front clip back together, I really can't see any way you could do that without at least removing the inner fender. Even then it would take a lot of flexibility and patience.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-25-2021, 08:53 PM   #3
royr
Appreciate the feedback.
Do you happen to know if the reproduced Jimmy emblems are plastic or metal?
Old 03-25-2021, 11:51 PM   #4
Blazerowner
Blazerowner's Avatar
I’ve done it with the inner fender in. Not easy but doable.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 03-25-2021, 11:57 PM   #5
royr
Unbolt the lower fender?
Old 03-26-2021, 01:23 AM   #6
Blazerowner
I don’t think I did. You have to use a small wrench and basically lay across the fender. If I did it again the inner fenders would come out. It’s a pain.
Kirk
Old 03-26-2021, 11:34 AM   #7
truckster
truckster's Avatar
Mine is a Blazer, so I can't say for sure, but the ones I got are nice, heavy metal.
Old 03-26-2021, 12:13 PM   #8
too much stuff
Roadtrip!
too much stuff's Avatar
I have done it from underneath the rear edge of the fender. You will need patience, and a longer 3/8ths ratchet wrench, and long arms.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-26-2021, 12:17 PM   #9
royr
Thanks, Mark at motorcityk5 said the same, but couldn't confirm on the Jimmy ones.
Old 03-26-2021, 12:21 PM   #10
royr
Thanks! And allot of cuss words I suspect If I can confirm that the reproduced ones are metal, I'll probably just cut the studs on mine. They need to be repainted anyway.
Old 04-04-2021, 09:55 PM   #11
Ptjsk
Don't cut the originals if you can help it.
I have yet to see, or have a reproduction item as good as the originals.
Pat
Ptjsk is offline   Reply With Quote
Old 04-04-2021, 11:45 PM   #12
royr
Pat
Point well taken. It would be headed for paint for a few months so have time to decide.
