Old 06-16-2021, 12:02 PM   #1
Zenwren
700R4 and TH350 internal parts interchange?
I'm planning to build a TH350 (probably a TH350C) for my 69 C10 and installing a Gear Vendors OD. I currently have a greasy 700R4 from an 88 G-van sitting in the shed, *supposedly* a good used unit. Would it be worth tearing into it to steal any upgrade parts to put in my TH350? I've heard about using a center support from a 700r4 in a TH350 for the wider sprag clutch, are there any other parts worth swapping or would I be better of just selling it as a whole unit and buying new upgrade parts? The truck is a mostly stock 350 and I'm going for just a rock solid daily driver trans, maybe occasional towing and a yearly burnout.
Zenwren is offline   Reply With Quote
Old 06-16-2021, 04:30 PM   #2
kwmech
Re: 700R4 and TH350 internal parts interchange?
As far as I know the only thing in common is the spline count on the output shaft. If you are wanting to build a 350c then you need that specific 350 case.
Old 06-17-2021, 06:08 AM   #3
Bigdav160
Bigdav160's Avatar
The low roller clutch and support is wider and does interchange. But I wouldn't tear a unit down to scavenge the part. It takes quite a bit of abuse to make the stock piece fail even in a TH350. Usually the splines in the case fail before the roller clutch.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-17-2021, 08:15 AM   #4
Stormin08
Stormin08's Avatar
why not save some cash and build the 700 ???
you can run a pressure switch fully internal to the 700 to control lock up...
my fully swapped 89 (no factory electronics left) works just fine
Stormin08 is offline   Reply With Quote
Old 06-17-2021, 01:32 PM   #5
Tom
driving is in my blood
Tom's Avatar
Sounds like a like of work for a mostly stock 350 that won't be beat on or drag raced with sticky tires. A stock th350 will handle that.
