![]() Join Date: Jan 2008
Hatch repair, where do I get these parts
Have started repair of hatch, was inoperable and couldn't be shut. Pics in my build thread.
After pulling it apart found some issues and need to source some parts. There is a handle reinforcement which I cannot seem to find online, and the clips (is in first pic) that hold rods. Any leads to where I can get these items, thanks |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Hatch repair, where do I get these parts
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#3 | |
Appreciate your input, learning as i go |
![]() Join Date: May 2011
That piece is not reproduced, I may have a good used one I'll sell but will have to look. The rod clips at the handle I can't find either, they have a tab that is straight. Everything online had a 90 tab so I've been using on door rod clips. There's a left and right in the doors you just need to figure out which one works best. Also, some of the tabs are longer than others so that comes into play sometimes.
Looking at you picture again and you location, lol. I would say just repair that one, I've seen them a lot worse.
Another question. Can someone tell me the specifications of the screw, No 7 in image. I believe this bolts into the reinforcement piece
It does, I can get a picture tomorrow, if no one else can help sooner.
![]() Join Date: Nov 2010
A photo sent to me by the Blazer Master . #10-24 screw
Some progress is better then no progress Last edited by Tmend; 08-20-2021 at 11:47 PM. |
There you go, lol
#11 | |
Here you go
#14 | |
Carpe manana
The metal reinforcement is probably not reproduced but perhaps the vendor has something similar as he is offering a reproduced hatch that presumably has a similar reinforcement.
#15 | |
The clips they show look identical to ones that were used on our 60 & 70's locally built GM Holdens, so I have ordered some from local supplier, and will see how they go. Appreciate your assistance As was mentioned earlier, if I have no luck I'll have it repaired or a new one made. Last edited by 68ls1; 08-23-2021 at 04:54 PM. |
#16 |
Here is what the original clips look like.
#17 |
Here are the ones out of the doors
#18 |
![]() Join Date: Dec 2002
The original ones are the same as Carburetor clip that hold the metal accelerator rod/linkage to the Carb. Might have better luck searching that
#19 |
#20 | |
#21 | |
#22 |
Part 2.
I am looking for the rubber gasket that mounts under the hatch handle and the rubbers that are on the hatch rods. What are the rubbers on the rods called and what do they do? |
#23 |
Carpe manana
You’ll have to make your own gasket using the old one as a template.
That rubber item looks like a plug used to secure insulation to the firewall. The loose rods I’ve had made use of a foam rubber block like those for the tailgate rods as an anti-rattle precaution I suspect.
#24 | |
#25 |
Carpe manana
Those will work. What I seem to recall is those for a hatch being slightly smaller than those for a tailgate. If that’s the case, those listed by LMC should be easily trimmed down.
