Old 11-03-2021, 09:07 PM   #1
TA_C10
TA_C10's Avatar
remove AN adapter from corvette filter
How do you remove the "out" side? There is a lip on the adapter that won't let me remove it. See picture below.
I've tried several different fuel line removal tools and they don't work.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 11-04-2021, 06:31 AM   #2
Thealien
Thealien's Avatar
Re: remove AN adapter from corvette filter
You can see the fingers that hold the fitting in in your first picture. I do not believe the tool you were using has long enough fingers?
If you can’t figure it out or someone else doesn’t chime in I’ll see if I can find the tool I use.
Old 11-04-2021, 07:51 AM   #3
95 S_Trucker
95 S_Trucker's Avatar
You need one of these:
https://www.amazon.com/OTC-6509-Fuel...40988629&psc=1
It is made to fit in tight spaces.
95 S_Trucker is offline   Reply With Quote
Old 11-04-2021, 12:54 PM   #4
TA_C10
TA_C10's Avatar
This makes sense, thanks guys. Tool ordered.
"It's only money".
Old 11-04-2021, 04:40 PM   #5
LS short box
Just FYI they have the same tool at car parts stores.
Old 11-19-2021, 10:29 PM   #6
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
probably could have just cut some of the excess off of the end of the tool as it does nothing??
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
