292 Motor mount
Thinking about doing a 292 in my ‘72 C10.
The Older Generation
Re: 292 Motor mount
You need to be a Premium member to post a WTB. If you see anything for sale on the parts board you can buy it, you just can't post the WTB. http://67-72chevytrucks.com/vboard/payments.php Thanks, LockDoc, Moderator
![]() Join Date: Mar 2003
Re: 292 Motor mount
If I was able to locate all the parts I'd be inclined to do the same. Never had an inline in any of the trucks I've rebuilt.
#4 | |
Re: 292 Motor mount
C3pilot |
Re: 292 Motor mount
Without looking I think the 6 month subscription is 15 bucks. Then you could post a WTB on the parts board. LockDoc
![]() Join Date: Aug 2019
Re: 292 Motor mount
There are a lot of people pulling l-6 engines. It should be easy for you to fine everything you need.
![]() Join Date: Dec 2013
Re: 292 Motor mount
The 250 /6 parts are easy , The 292 Passenger side engine perch not so easy .
![]() No, Sorry there not for sale .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#8 | |
![]() Join Date: Feb 2002
Re: 292 Motor mount
Forged from refined Inobtainium. However, unnecessary in a C/10 installation.
Re: 292 Motor mount
Was the inobtainium brought in from Pandora?
Re: 292 Motor mount
I'll have to look inside the box to be sure...
Re: 292 Motor mount
passenger side 292 motor mount perch is available through " stove bolt" or "12 bolt" ( I think). I've had one for 5 years with no problem. Only thing is it covers up your mechanical fuel pump mount and hole in the block, means going to an electric pump.
Re: 292 Motor mount
I've seen those, but I'm not interested. They anchor a 292 like a 250. The symetrical layout is fine for the smaller displacement, but 292s have massive torque, which is why GM went to the trouble of the more forward passenger-side mount. And the electric fuel is a deal breaker for me.
Re: 292 Motor mount
How come the passenger side perches are harder to find? Just curious
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
Re: 292 Motor mount
I'm thinking there were less produced ,But so many 6 cylinders were swapped over to small blocks and you can just drop a small block in place of the 250 using the same 250 engine perches .You can't use the right side 292 perch with a small block so they probably got tossed off to the side and replaced with a 250 right side perch or a set of small block perches ? anybodies guess ? there are probably a bunch laying under garage work benches all over the country . Last I noticed they were selling for about $100.00 for the right side .
#15 |
Re: 292 Motor mount
Be nice if somebody could stamp some more out, instead of a goofy way to foul up the Mechanical Fuel Pump.
#16 |
Re: 292 Motor mount
I've got a question about this. If it is not a nut an bolt restoration could you move up to the 73 frame and engine mounts?
#17 |
Re: 292 Motor mount
You could, I guess. You could move all the 67/72 body parts over too. But the 292 would still need its own RH Mount.
#18 |
Re: 292 Motor mount
#19 | |
Re: 292 Motor mount
You can use the '73 frame brackets on the SB and BB engines with a little modification but I think it would take quite a bit of modification to use them on the 292 engines, at least on the right side. LockDoc
#20 | |
Re: 292 Motor mount
#21 |
Re: 292 Motor mount
Sorry, I didn't proof read my question. I meant to use the frame brackets.
#22 | |
Re: 292 Motor mount
Good deal! Thanks. That will be your best bet for finding something. LockDoc
