1969 K10 front sway bar
Has anyone out there installed a front sway bar on their K10 with a Dana 44 in the front? I have a 1978 truck and it drives much nicer with the sway bar.
![]() Join Date: Jan 2002
Re: 1969 K10 front sway bar
I installed one on my 1971 K10. Not sure if there are any frame differences between the two years.
I went to a junk yard and took one from a square body including the frame brackets. (Hammering the rivets off was a pain . . . . ) It turns out swapping the frame brackets to opposite side and a little trimming they fit my 71! I can take a few pictures if you would like. Doug
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
#3 | |
![]() Join Date: May 2007
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
![]() ![]() Join Date: May 2015
Youd also need the spring plates that the sway bar fastens to
![]() Join Date: May 2003
If you follow this thread starting at post #277 you can see how I did mine. I use the parts from a square body, but kept my original front cross member, and modified the brackets to fit.
Gary http://67-72chevytrucks.com/vboard/s...259859&page=12
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
