Old 01-03-2022, 12:34 AM   #1
65Custom
Side mounted gas Tanks
I have searched the forum and I have not found any post on side mounted gas tanks? SO wondering if anyone has managed to mount a saddle type tank on 64-66 C10?
I have looked at the 73 -87 tanks and they look like they might work but wondering if anyone has done it
I am planning on putting in a tank between the frame rails in the rear, but I also do not want to get rid of the gas filler in the side of the cab. I would like to keep it if possible. so wondered if anyone put in a side mounted tank?
I was thinking that maybe I could run the cab mounted filler to it through the floor and have an additional fuel tank and keep the original look.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 01-03-2022, 10:43 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Side mounted gas Tanks
There sure are many threads on relocating the fuel tank. See FAQ "Fuel tanks" - http://67-72chevytrucks.com/vboard/s...d.php?t=646002
However I have yet to see one on a saddle tank for our trucks. Hopefully someone else will add their experience.
Old 01-03-2022, 08:01 PM   #3
AcampoDave
AcampoDave's Avatar
http://67-72chevytrucks.com/vboard/s...=621177&page=2 see post #28
AcampoDave is offline   Reply With Quote
Old 01-03-2022, 11:40 PM   #4
65Custom
Yes I have seen many for between the frame rails in the rear but finding one where they used a saddle tank I have not seen, thought I had seen in the past but when I looked this time I was not finding anything
My Build Thread
I must be
Old 01-03-2022, 11:42 PM   #5
65Custom
Originally Posted by AcampoDave View Post
Thanks I see that post and that is close to what I want to do, I was hoping someone may have used a tank from a later truck that would bolt right in and not something custom, but either way it seems like it would be doable.
My Build Thread
I must be
Old 01-03-2022, 11:49 PM   #6
65Custom
I thinking of maybe something like one of these tanks but assume that the tank would not sit up under the cab at all and that would be issue for connecting the filler neck, may give this a shot and see how it measures out
https://www.classicparts.com/1982-86...tinfo/23-952/#
with the associated brackets
https://www.classicparts.com/1973-91...ctinfo/23-989/
https://www.classicparts.com/1973-91...ctinfo/23-988/
My Build Thread
I must be
Old 01-04-2022, 12:09 AM   #7
62bagger
62bagger's Avatar
I know they used to make saddle tanks for these trucks because when I was a young man my neighbor had a 65 long bed with a cab over camper and he had them. They were more squared welded tanks not stamped. They hung below the bottom of the bed just a bit in front of the rear wheel. I don't know if they are still made.
62bagger is offline   Reply With Quote
Old 01-23-2022, 05:38 PM   #8
JiminyFixit
My 65 has a second tank under the bed. I am planning on removing it as it has not had the fill hose on it for a long time and the tank is filled with who knows what.
There is an after market fuel door on the front drivers side of the bed. At this time I'm going to leave the door.
I'll try and post some pics if you would like to see.
Let me know.
JiminyFixit is offline   Reply With Quote
