Old 01-16-2022, 01:13 PM   #1
Johnl48
700r4 to 205
Doing a 4spd to 700r4 conversion. Guy at advanced adapter s told me I just needed the tail shaft changed, which I did, and it will bolt right to the 4spd adapter...guess what.. it doesn't, the bolt pattern is totally different and the hub they provided is too deep What am I missing ?
70 c20 350
Old 01-16-2022, 02:22 PM   #2
kwmech
Re: 700r4 to 205
You need a factory T350 to 205 adapter. I may have a couple of them hidden in a box somewhere
Old 01-16-2022, 02:33 PM   #3
Johnl48
Re: 700r4 to 205
I'm glad they told me it will fit on the 4spd adapter. Please let me know if you have one I'm stuck here
Thank you
Old 01-16-2022, 07:34 PM   #4
Johnl48
Re: 700r4 to 205
Found one local thank you
Old 01-17-2022, 12:12 AM   #5
57taskforce
All about them K’s
57taskforce's Avatar
Re: 700r4 to 205
The th350 and 465 205’s use different case input shafts and transmission output shafts as well. 10 spline course input and output on the 465 and 27 spline fine on the 350 if memory serves me. I believe there is a conversion coupler made that will make this swap work….
Here’s said coupler…
https://www.offroaddesign.com/drive-...10-spline.html
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 01-17-2022, 08:49 AM   #6
Johnl48
Re: 700r4 to 205
Correct. I have that and new tail shaft is in transmission already
Old 01-17-2022, 05:10 PM   #7
kwmech
Re: 700r4 to 205
Couldn't find mine, glad you found one
