Old 12-29-2021, 09:22 PM   #1
Mike80D
Mike80D's Avatar
Help with frame stamp ID
Truck is a 5/25-31 Flint built 72. It has 5-11-20 stamped on the side of the frame near the driver’s door area. The 20 is really throwing me for a loop. We’re frames built off location and that’s a plant code perhaps??
Mike80D is offline   Reply With Quote
Old 12-30-2021, 06:03 PM   #2
BigBird05
Re: Help with frame stamp ID
To the best of my knowledge there were 2 frame venders for GM. One was A.O. Smith I can remember the other one.
BigBird05 is offline   Reply With Quote
Old 12-31-2021, 02:30 AM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Pic of similar for a 1971 C10, SWB & leaf springs. I don't know what the numbers mean less the part number. For what worth most of the stamped parts on the truck are April 1971, the truck was built May 1971, Fremont. 4-23 seems to imply April 23, but 26 is the same mystery as yours.
Know what 670 on your frame means?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-31-2021, 07:50 AM   #4
Mike80D
Mike80D's Avatar
I'm not sure what the 670 means. Thanks for your reply.
Old 12-31-2021, 12:09 PM   #5
BigBird05
Here are the #'s from my 72 frame, LH rail A41772 B005, RH rail A4672 B906. Probably adding more confusion than helping.
Old 01-03-2022, 11:49 PM   #6
71CHEVYSHORTBED402
Just guessing the 670 in the OP is a call-out or whatever term and means for example this one is 4x4, coils and so forth. It's what makes trucks special
20 might be the factory number, for instance. I remember working for a franchise and the numbers weren't in numerical order. I wonder how many factory's built these? Figure GM pumped out approx. 9K trucks some months just Fremont alone, that's a lot of frames.
I looked on the web for 70s GM frame stamp and casting, everything close just turned up this website and still empty.
Tony
Old 01-04-2022, 11:05 AM   #7
MJN
MJN's Avatar
This link has some better information on how to breakdown the frame stampings- given its focused on Chevelles but since AO Smith was one of the major frame suppliers the codes may carry over.
http://chevellestuff.net/qd/frames.htm
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 01-04-2022, 12:35 PM   #8
Tomchev
Went by AO Smith building in Milwaukee years ago and there were car frames stacked as high as the fence around the building.
Tomchev is offline   Reply With Quote
