Old 01-31-2022, 11:44 AM   #1
blazer2007
electric door install. Fender on or off ?
I have a 78 short box and I,m finally going to install some electric doors I,ve been packing around for some time. I found some info on where to drill the holes ,but it said take door off ,drill holes and intall new door. Got door off but doesn,t look like much room to drill, maybe with some sorta angle attachment.
What have you done to drill the holes. I don,t really want to take fenders off. I,m running out of room in my small garage. I have hood off, engine out, parts all over and can barely get around the garage now and there is lots of snow outside.
blazer2007 is offline   Reply With Quote
Old 01-31-2022, 12:27 PM   #2
kwmech
Re: electric door install. Fender on or off ?
Swapped power doors onto my tow truck several years ago from a Suburban. Never considered or had to remove the fenders for the swap. Removed the doors, drilled a hole, shoved a grommet in it and shoved the harness in. bolted the doors on and plugged the harness in... Done. Took me about 3-4 hours start to finish. One of the easiest swaps I've ever done 85 doors on a 79 truck
Old 02-01-2022, 11:20 AM   #3
blazer2007
There is no way I can see drilling straight but I don,t see well anyway. Here is a pic straight on and then on a angle. I guess I will have to find a wobble bit or a angle attachment. Always something else to buy.
Old 02-01-2022, 11:49 AM   #4
kwmech
Ahh yes. I do have an angle drill from snap on and a set of short bits going up to 3/8 along with step bits
