Old 02-26-2022, 10:19 PM   #1
Bushman66
Captain Fab Power Steering conversion column alignment question (with pictures)
Hi all,
I got my power steering box into my 66 C10 using Captain Fab's bracket. If you look at the pics, the (stock) column is perfectly aligned with the input shaft on the box, but the column shaft is offset about 1/2" toward the passenger side. I'm afraid this is going to put stress on the rag joint when I hook it all together.
Note: (The flange is not set in final position on the shaft yet).
Any suggestions? Anyone run into this before? Is there an adjustment I can make up under the dash to shift it closer in line with the box?
Thanks!
Bushman66 is offline   Reply With Quote
Old 02-26-2022, 11:03 PM   #2
62bagger
62bagger's Avatar
Re: Captain Fab Power Steering conversion column alignment question (with pictures)
Is there a universal type of connector on the shaft?
62bagger is offline   Reply With Quote
Old 02-26-2022, 11:09 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
On the 60-62, stock steering column there is, but on the 63-66 stock column, it's a solid rod from gear to wheel
The shape of the power steering gear causes the steering gear to be out of perfect alignment with the stock steering shaft because it doesn't sit in the proper spot without cutting into the frame. I think a lot of people have just run it with the rag joint taking up the difference
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 02-26-2022, 11:21 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Not on mine, it is aliged perfectly. Check your body alignment side to side. Maybe cross measure your frame for squareness?
Old 02-27-2022, 12:04 AM   #5
Bushman66
Will do, but the stock box lined up perfectly, so if the frame or body were out of square, wouldn't it affect that as well?
As far as I know (GF's family owned it from new), and what I have seen, this truck has never been in any major accident. Box is a new (reman) Lares 71 C10 box. Captain Fab's bracket went in perfectly, using the template he supplied. Wondering if there is a way to adjust the column itself over a bit in the under dash area?
Old 02-27-2022, 12:24 AM   #6
MT65
There’s a solution if you go up the steering shaft closer to the firewall, machine the shaft to accept a Borgeson u joint with 3/4dd to prevent spinning, then down to the rag joint on much less of an angle…..have done this with just 2 ujoints on street rods many times, they make a joint that is a vibration isolater also…
MT65 is offline   Reply With Quote
Old 02-27-2022, 12:29 AM   #7
Bushman66
Thanks MT65, I was hoping to avoid messing with a bunch of U joints and such. Hundreds of guys have used Captain Fab's bracket for this conversion without this issue so I'm hoping its an easier (and cheaper) answer... The shaft is perfectly inline with the input shaft (theoretically negating the need for U joints, its just offset to the right, compared to the box input shaft for some reason...
Old 02-27-2022, 12:42 AM   #8
MT65
Understand, just been through this before, no its not cheap, joints are spendy and machining can be also, I have my own mill so it doesn’t hit me so hard…
Old 02-27-2022, 11:22 AM   #9
61hawk
61hawk's Avatar
Nevermind, I just looked at the pictures.
61hawk is offline   Reply With Quote
Old 02-27-2022, 05:34 PM   #10
Bushman66
I'm dumb. Right in the directions it says to loosen the steering column bolts. I reached out to John, he responded (Thank you sir). Loosened the bolts and a little pulling has them almost perfectly in line. Thanks to all who responded, love this board!!
Old 02-27-2022, 06:33 PM   #11
The Rocknrod
Moderator
Not at all, it's just a process. We ALL have had issues.
Old 02-28-2022, 09:49 PM   #12
MT65
Rocknrod is correct, we’ve ALL had some variety of issues, if you say you haven’t it boils dow to two scenarios,
1- you aren’t being truthful
2- you haven’t done anything….
Old 03-04-2022, 05:45 PM   #13
Bushman66
All buttoned up, no leak, no issues. Took me a couple of tries to get the right belt, needed one that allowed the pump to adjust far enough out that I could remove the cap from underneath the alternator bracket.
Anyway, thanks for all the help here, the PS is a game changer in the drivability of the 66.
