1970 Daily Driver
16 Tires on C20
Picked up a project truck. Replaced the missing carburetor and with a little time the 402 is running pretty dang good. Now I need to get some shoes that don’t look like they’ll explode just by looking at them. The truck has 235 85 R16 on it right now but I was thinking of going to a 265 75R 16 to fill out the wheel wells a little more. Looking for advice.
looking at getting these tires https://www.ebay.com/itm/39360416413...MAAOSwJPphVfkZ .
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 10-28-2021 at 11:46 AM. |
![]() Join Date: Mar 2015
Re: 16 Tires on C20
I'm very happy with the 265/75/16, as you say it fills out the wheel well nicely on a 3/4 ton.
![]() Join Date: Mar 2003
Re: 16 Tires on C20
I've got 285s on my 68 with an alum rim
1970 Daily Driver
Re: 16 Tires on C20
Your truck looks awesome! Did you mount them on the Chevy 6" rim or find a set of the f*rd 7" rims?
Any pictures of your truck with the 285s?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
![]() Join Date: May 2001
Re: 16 Tires on C20
You might check those eBay tires, I dont think they are LT rated, just P rated. Im sure they are offered both ways.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
Re: 16 Tires on C20
here ya go
#7 | |
Re: 16 Tires on C20
https://www.roadreadywheels.com/prod...teel-wheel-rim |
#8 | |
Re: 16 Tires on C20
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 10-28-2021 at 01:36 PM. |
1970 Daily Driver
Re: 16 Tires on C20
Has any one tried the 265 75R 16 on a 6" rim?
![]() Join Date: Oct 2017
Re: 16 Tires on C20
Re: 16 Tires on C20
Re: 16 Tires on C20
Thanks !
Re: 16 Tires on C20
Here is my '69 C20... it has 285/75/16 tires, they need to be replace, looking at the 265/75/16....
Re: 16 Tires on C20
these were the closest metric size LT tires to the originals on these longhorns..
LT245/75R16 BFG A/T KO2 tires on Chevy 6.5" wheels ![]() LT245/75R16 Goodyear Wrangler tires on ford 7" wheels ![]()
I started out with nothing - and I still have most of it |
#15 |
Re: 16 Tires on C20
235 85 16 and 265 75 16 are virtually the same height just different width. Either is a good choice, but I prefer the wider tire look. If you plan on running a 6 rim I would stay with the 235 although lots of 265 installed on the 2000-2008 GM 6.5 rims. I ran 265 75 16 0n my 70 C2500 on Alcoa super single forged wheels and it looked fantastic. The math, if you are interested:
265 is the section width in millimeters. There are 25.4 mm per inch. 265/25.4= 10.43 inches wide. The profile is 75% of the section width: 10.43 x 75=7.825 sidewall height. Times two for the bottom of the tire and top of the tire = 15.64 inches high. Added to the 16 rim diameter you have a tire 31.64 tall and 10.43 inches wide. 235 85 16 tire is 9.25 section width and 31.72 tall. 245 75 16 is 9.64 wide and 30.4 tall 285 75 16 is 11.2 wide and 32.8 tall.
#16 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: 16 Tires on C20
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#17 |
1970 Daily Driver
Re: 16 Tires on C20
Found these on craigslist. Seems like a good deal.
Can you run beauty rings and the stock dog dishes at the same time?
#18 | |
Re: 16 Tires on C20
Edit: They look just like the wheels that were on my 98 GMC Savanna van trim rings and center caps that were held in place with the plastic lig nut caps
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#19 |
![]() Join Date: Dec 2014
Re: 16 Tires on C20
That's correct, I imagine that those would work with conversion lug nuts and modern hub covers. I just picked up a set myself. At that price it's a good option if you are into that look.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
#20 |
1970 Daily Driver
Re: 16Β Tires on C20
Well I bought the rims and tires before coming back to this post.... I did plan on using the hub caps dang it.
Has any one added the s clips to make them work? https://www.pelicanparts.com/More_In...BoCEDsQAvD_BwE
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 11-11-2021 at 04:07 PM. |
#21 |
At the body shop.
Re: 16 Tires on C20
245 75 16 on a 7 inch wheel
" That didnt make it any newer " " Dont antique the equipment " |
#22 |
1970 Daily Driver
Re: 16 Tires on C20
Got the rims. Hoping I can drill and tap three or four holes and use button head machine screws to Act as the missing knobs to hold on hubcaps. I set one on there to see how it would look. If I’m successful I will post to pictures.
#23 |
Re: 16 Tires on C20
I can't recall if I had posted pictures of the new tires in another thread or not...well these are Firestone LT 265 / 75R 16...I also had the rims powder coated white ( the originals were silver ) I like how the white shows against the black ! I'm also attaching the SPID, would like to know the type of rear-end / ratio ( I'll write this down this time )
Thanks again ! Steve |
#24 | |
Re: 16 Tires on C20
#25 |
Re: 16 Tires on C20
