What kind of master cylinder is that and which one fits?
Hello community, my truck has a master cylinder for 4 disc brakes installed, but I have a disc/drum, I'm guessing it's from a Corvette, isn't it? Can I install a normal master cylinder from the 1976 truck, does it also fit on the brakebooster?
Fits the screw connection to the brakebooster? I can't identify it. Thanks
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 Last edited by Braunschweiger; 04-12-2022 at 01:33 PM. |
Moderator
![]() ![]() Join Date: Aug 2011
Re: What kind of master cylinder is that and which one fits?
It "looks " like a corvette or camaro master cylinder. It is a shallow depth (where the pedal rod pushes the piston).
Thanks, does a "normal" disc/drum" master cylinder fit from the brake booster bolt on ?
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
Moderator
Thats a good question, I assume it would. Depending on the master cylinder chosen.
I'll see, I'll select a master cylinder for disc/drum that is suitable for brake boosters
![]() ![]() ![]() Join Date: Jan 2018
Looks like the same aftermarket master cylinder on my truck. The key thing is your proportioning valve hanging off the side of the MC. If it was a kit used by the previous owner, It's probably already set up as disc/drum
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
No, it was set up incorrectly by the PO, I have now ordered an original master cylinder for a brake booster and rear drums from the '76 C10. I hope it fits on the brake booster
![]() Join Date: Sep 2006
The master should fit no problem. You might have to get a different push rod though. You will know when putting the new one on.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Yes, I hope and think so too.
I measure it before installing
But Found Her 25yrs Later!
Side thought... I put one of these in line to the rear brakes. That way I can dial it in to not lock up the rears depending on the load in the back.
https://www.summitracing.com/parts/s...RoC43kQAvD_BwE
Good tip, I think I still have one lying around, I'll take a look
