Relays needed after rewiring?
I am finishing up a Painless wiring and upgrading to blade fuses, etc.
I think one of these is the horn relay (do I still need this or is it embedded within the new fuse box? Also I don’t know what the other 2 relays are or if I need them at all….I’m running out of wires to terminate. Thank you John Posted via Mobile Device |
![]() Join Date: Feb 2016
Re: Relays needed after rewiring?
The 2nd photo shows the transmission kickdown switch for a T400.
On the others what year is your truck? Not knowing which painless harness you have we have no idea if it includes a built in horn relay. And welcome aboard. We would enjoy seeing some more pictures of your truck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
The relay with green wires on your fuse block in photo 1 is almost surely a horn relay.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#4 | |
Thanks for the feedback! Here’s one current state pic. I won’t bore you with all the transition photos but it’s come a really long way, with more to go.
I used the painless #10206 harness system. I do have the TH400, do I need to route that lockdown switch to something? I don’t remember if it had something when I ripped out all the old wiring. It was in good running condition beforehand though. Quote:
![]() Join Date: Mar 2015
I do have the TH400, do I need to route that Kick-down switch to something?
Yes, but the transmission will work with out it. Nice to have though. 12V to the switch and the switch to the connection on the side of the THM 400. I provides 12V to the transmission when the truck is floored. If you kept the old wiring maybe the wire is still there. It is a separate wire as in not part of the main harness. Circt 924 Green wire 14g Connect HEADLIGHT SECTION A wire #924 (grn) to the Horn's hot terminal. TURN SIGNAL SECTION wire #953 (blk) was connected in the turn signal connector section of these instructions. The horn relay is pre-wired into the fuse panel. Last edited by Accelo; 04-19-2022 at 02:04 PM. |
Thank you again for the info. Tracking the horn should be good to go. I did route the #924 and grounded it.
So the kickdown switch above the gas pedal should route to the blade in this pic? Optional but advantageous to use when desired. Thanks for the help Posted via Mobile Device |
Yes that is exactly correct.
You could easily build your own or you can purchase the harness separately if you like. Remember to get the one for the 72. The earlier ones had the switch on the intake manifold not inside the cab like yours. |
