Old 04-26-2022, 06:30 PM   #1
Alex69c10
CPP Trailing Arms - U-Bolt holes
Hey all
My CPP tubular trailing arms arrived yesterday and the new U-bolts. The u bolts are the same size as the old ones, so fit a treat.
The holes in the trailing arm are large than the u bolts, allowing for the axle to move, so I was wondering if this was normal? Or have people bushed it/aligned and torqued down?
Just don’t want that sucker shifting.
Thanks all
Alex
Alex69c10 is offline   Reply With Quote
Old 04-27-2022, 07:02 AM   #2
Joyridin
Re: CPP Trailing Arms - U-Bolt holes
How much bigger? They usually are a bit bigger and sometimes the U-bolt will spring a bit and it is hard to get in place. Once you tighten everything down though, it shouldn't move. I would think the holes might be about 1/8" larger in diameter than the bolt, but not more than that.
Joyridin is offline   Reply With Quote
Old 04-27-2022, 11:42 AM   #3
Sim6
Sim6's Avatar
I know what you are talking about. I'm currently using a set that is smaller in diameter. No issues to report but my long term plan is to thicker ones with blocks to lower it more.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
