Moderator
![]() Join Date: May 2007
How much work to modify a 4x4 suburban frame for a LWB truck?
Been looking for a K10/K20 chassis with no luck. Ran across a 68 or so suburban 4x4 frame. I know the wheelbase is the same as a LWB truck, but what all is involved in “converting” it to work as such?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Re: How much work to modify a 4x4 suburban frame for a LWB truck?
My 4x4 in my build thread is a 69 suburban frame. I had to add rear cab mounts to it. Also the front cab mount holes have to be elongated. The front rear spring hanger is different on a suburban , I would guess because it incorporates a body mount that you will have to remove.
Add bed mounts and you will be ok. I sat my cab and bed on it after all that and there are pictures of how it lines up. I did shorten my frame , but that wont affect your project.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
Yep, just a matter of body mount differences to change, and you gain a rear tank!
Moderator
Thanks for the info! Got some pics of the frame in question and unfortunately it’s bent so I won’t be buying it
All about them K’s
![]() Join Date: Jun 2014
If you don’t mind traveling; I’d bet Kevin (undertaker72) might have a K LWB frame. He’s a little south of Salt Lake City.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Have you considered buying a later sqarebody K frame and swapping components to a 68-72 2wd frame. I know its a lot of work, but they are fairly interchangable. The appeal of 14 bolt 3/4 ton stuff makes the heavier ones a little harder to find.
I don't know California rules.
Do you need the title of the frame to do a frame swap? In some states, you need both the title of the frame and cab to be legal.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
I suggested adding the 4wd components to the org frame as another option .As far as a complete frame swap, it may be an issue in other parts of the country.
#9 | |
Moderator
I’ve considered that too, DIY4x and other companies also make hangers but it is a lot of work and a lot of money going that route. Easier for me to swap everything over if it just bolts on. I don’t really need 4wd but it will allow me to lift my truck easier/higher with leaf springs. I may just swap out my front spindles for 88-98 4” lift spindles and see where it lands.
All about them K’s
I’ll keep my eyes peeled for one closer to you.
Moderator
Thanks Tyler, appreciate it.
