Location: 3,018 feet above the SoCal/Mojave Desert region.
Center drive shaft bearing or one piece drive shaft??
Has anybody done a one piece drive shaft??
![]() Join Date: Dec 2013
Re: Center drive shaft bearing or one piece drive shaft??
Replaced the one in my 70C10 and loved it. I lost count of how many rubber 'bushings' I had to replace for the 3 piece.
![]() Join Date: Jun 2014
When I bought my truck, PO had a one piece drive shaft in it. After I installed a new motor/transmission with the correct motor mounts, the existing driveshaft didn't seem to fit (too short). I ended up having another one piece made by a driveshaft shop. The guy was pretty knowledgeable and said that the driveshaft that I had (brought it in with me) was too small in diameter, and would have definitely caused vibration when driving at higher speeds. The new one is much bigger in diameter and I won't know of issues until I finally get it back on the road.
I think you will find people in this forum that will argue both ways concerning the merits of a one piece vs 2 piece drive shaft. |
Old member
I had 2 piece for many years and had no major problems. I had the 6.0 installed and they cut the 2 piece to short. So they had a 1 piece installed at no cost to me. I have no problem with it and I have a LWB truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Apr 2011
Did a one-piece with my LQ4/4L80e in my LWB. No vibration or noise. Happy with it. I say go for it.
A good drive shaft shop will ask your max engine rpm and length then determine shaft diameter. Mine is 3.5" diameter.
I went to get my drive shaft shortened and made into a one piece. Long story short I'm getting a 3.5" one piece drive shaft made. My question is was does the cross member need to be modified or will it fit in?
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
Mr. Cheyenne
![]() Join Date: Jun 2020
hmm, what the benefit of actually going one piece drive shaft (I get you get rid of that carrier bearing)? There has to be a good reason to have a two piece with a LWB, right?
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#9 | |
![]() Join Date: Dec 1999
I have 4/6 lowering with LS 4L80E swap and was hitting the top of the crossmember... |
#10 | |
The driveline is also affected by any unusual or unpredicted system resonances, which can destroy a driveline even at a speed lower than the critical rpm. From an OE perspective the driveshaft choice (one piece vs two piece) can be manipulated by controlling any one or more of those variables. The trade off is the added cost of the two piece system vs selling a vehicle with a top speed which is lower than desired. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() Join Date: Aug 2019
Keith I love your opinions. Did you make the move to Pontiac? I was there from 97 till I retired in 2002. I worked in the engineering bldg.
Thank you - I did.
When I came back from the Desert I was at the Tech Center in Warren ever so briefly, and then moved to the white castle on South Blvd. We were in Pontiac for several years, before they shut down the Truck Validation Center and all of CenterPoint completely and shipped us back to Warren. K
A 4" shaft will also fit in the driveshaft hole for the trailing arm crossmember, if your interested. But, if you go low, you may need to raise the top of the hole to prevent driveshaft interference at max suspension travel (I put up some pictures of what I did on a different thread).
I replaced my one-piece 3.5 driveshaft on my long-bed with a 4" driveshaft when I did a tranny swap-if you look into "critical speeds" of driveshafts, when they get as long as they need to be for a long-bed, you start reaching this critical speed (rpm at which point the driveshaft becomes unstable and starts whipping like a jump rope) of a 3.5" driveshaft around 85MPH depending on specifics of gearing, etc. Jumping up to a 4" driveshaft gives you substantially more RPMs/speed before reaching this point. |
Thanks for the input guys. I have been getting an education on this matter. I have removed the center bearing carrier bracket since I won't be using it. From what I understand I should be ok since I'm not doing a big drop.
![]() I should have stated that I changed the truck from LWB to SWB and its currently at standard ride height. If I do drop it I will probably do a 2/4 to close up the wheel opening gap.
#15 | |
#16 |
I know this is an old post, but do you know the drive shaft diameter and have you had any trouble with it hitting the crossmember? Is yours swingarm rear?
#17 |
