Looking for a quality 4" rear drop spring
I used to get my springs from Early Classic Enterprises and they were always great, spot on, exactly as advertised. Now I'm helping a friend try to find a true 4" drop rear spring and reviews of competitive brands are all over the map. CPP has a "heavy-duty and a standard duty, Mcgaughys springs are said to be "soft and produce lower than desired drops and LMC....is LMC...enough said. Anybody have a recommendation for a true 4" drop rear spring like ECE used to sell?
https://www.performanceonline.com/19...-Coil-Springs/ what about these, at least we know they are made in USA . Last edited by AcampoDave; 10-17-2022 at 01:03 AM. Reason: Added link |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Looking for a quality 4" rear drop spring
I have those on my truck, I like them.
Have you considered air bags with schrader valves instead of springs? That's what I'm using on my '66 to get around the inconsistent spring height issue, and still be able to haul a lot of weight when needed. I used D2600 bags with upper cups that mount using the stock holes so no mods to the truck were needed.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#4 | |
![]() Join Date: Sep 2022
![]() Join Date: Mar 2016
I bought 4" rear drop springs from the truck shop. This is where it sits after the install.
![]() Join Date: Apr 2014
I have the CPP heavy duty 4” springs on my daily driver ‘66. They ride good and still have enough support to haul things in the bed. The only downside I can say is the coil windings are much tighter than stock or other brand drop springs. They are so tight it is very hard to even slide an open end wrench into to hold the spring cups making installation or taking them off the trailing arm a PITA!
Here is my truck 2/4 drop with 255/70/15 rear tires. Edit: Admins could someone fix the upside down photo? Last edited by SidsChopShop; 10-19-2022 at 12:49 AM. Reason: Photo needs flipped |
Rotated....
I used 97-06 Jeep TJ rear coils for a 4' drop. AC Delco 45H2104 variable. 653lbs.
![]() Last edited by AcampoDave; 11-15-2022 at 11:25 PM. Reason: Added ol' glory |
Be sure to follow-up w/some before & after images for future reference.
I used the CPP rear panhard #6572DTBK. It's longer than stock, adjustable and the bottom attaches at the perch. I have a squarebody rearend that lacks the integrated attachment point on the axle housing so attaching at the perch was a must. The longer length will give you less side deflection as the rear travels up and down.
We put a Chinese made shock relocator kit from Amazon. The grade 5 hardware sucked with cheesey lockwashers but the brackets seemed decent. Oh, and we bought KYB shocks from LMC.
Sorry, no pics today. The problem was it had 5" rear drop springs but it was on the bump stops. The 4 inchers gave it just enough free travel to provide a comfortable ride. I know some guys will shave the bumpstops and all that, but in this case we're trying to build a longer distance driver suited for a variety of conditions so practicality was the big factor in raising it up. We changed from a 4.5ラ5 to a 2.5ラ4. Removing the 2 " drop springs in front but keeping the 2.5 inch dropped spindles and swapping 5" drop springs in back for 4 inchers.
