![]() ![]() Join Date: May 2015
L33 question
I have a chance to pick up a 2006 L33, sadly it has no ecm or any of the throttle controls
I would want to change it to a dbc setup.. that's easy enough Also plan on electric fans And want to run AC Will also be running a BP harness and manual trans The question what ecm do I need , I'm confused as to what i would need In my search it says 24x reluctor
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 12-27-2022 at 06:40 PM. |
![]() Join Date: Mar 2015
Re: L33 question
The L33 is a 5.3L, Gen. 3 small block engine used in GM trucks between 2005 and 2007. This motor also has the excellent 799, 243 heads installed. You also get larger valves than most of the 5.3L.
This is the desirable Aluminum block, if you are not boring or turbo-charging. The aluminum block saves about 100 pounds. The L33 used the 24x reluctor wheel. You will need the matching computer to the reluctor ring, they do not interchange and software can't change this. Black crank sensor is 24 and I believe grey is 58 If you modify the motor don't forget to get it tuned at your local chassis dyno tuner. If you skip this step you may be leaving a lot of HP on the table. The most straight forward approach would be to use an older P01 PCM (0411) programmed as a 2002 LS1 Camaro. This would get you the DBC, cooling fan. Note; there are other options for the computer. Confirm with the fellas at https://bp-automotive.com/product-ca...wap-harnesses/ They will confirm and flash the ECM. Many companies will provide the ecm if you inquire. Cheers Last edited by Accelo; 12-27-2022 at 12:00 AM. |
Re: L33 question
Re: L33 question
I would get the ECM from BP since you are getting the harness from BP. They can load a base tune to get you running.
BP can also include wiring for either one or two fans and also set the on off speeds. Same for the AC. Doesn't say what you plan for a trans. I suspect BP can supply connectors and tuning for all the popular LS type transmissions. I would pick up a used mass air flow sensor for the same year engine. Good luck with your project. |
Re: L33 question
my bad, i thought i had manual trans in the above post..
ive sent BP a email for their recommendations , and will most likely go with their complete system i was thinking i would need to source a ecm, so that fixed that issue.. now , if he dont sell it before i can get there
Re: L33 question
BP got back to me , they've got everything I need ....thanks.!
Re: L33 question
Sounds like you have it under control but FYI, I have an '06 L33 and picked up harness and computer from PSI. I did call and explain to them that I'm running a DBC set up rather than the stock DBW and they were able to get me going. Had I known about BP Automotive, I'd have gone with their setup.
Re: L33 question
You also may want to consider a Holley Terminator X setup. More versatile than a stock ECU, And potentially less hassle unless you have a local supertuner who does stock ecu's
81 short step. |
![]() Join Date: Nov 2015
Re: L33 question
I have a 06 l33 , I recently finished a swap into my 72 C10. I considered PSI and BP for a complete set up, but after considering my needs and the cost of each system, I decided on the Holley terminator X, as I plan on adding a bigger cam and ported heads later this winter/spring and didn’t want to pay for a tune twice.
The Holley system does a pretty good job getting you going and learning your tune after some input, that said, I may need to have a tuner look at the tune once mods are complete, to maximize everything. I too wanted DBC, and a Manual transmission so I didn’t have the expense or need for the Terminator X Max. I also didn’t need a Tac module, or matching gas pedal, or MAF, (SD tune)so I saved a bit there too. I’m not trying to change anyones mind on a traditional harness or ECM, or that one system is better than another, just saying that the Holley terminator is worth a look.
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, FAST 102/102, FIC injectors,BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
Re: L33 question
The Holley system has a good rep over LS1tech.com The is a guy on that site that does remote tuning. I think it isAndrew70? He also has a good rep.
Re: L33 question
His name is Andrew, his username on LS1Tech is Project GatTagO.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Re: L33 question
Thanks to all.. the engine got sold about 1hr before I got there..
