10-28-2023, 06:45 AM | #1 |
Intermediate Shaft Question
I will be installing an aftermarket steering column in my 67 C10 so I also ordered the intermediate shaft as well. My question is, the intermediate shaft I ordered didn't come with any pin to insert in the hole (shown on attached pic). What kind of pin goes through this hole? Thanks.
10-28-2023, 07:11 AM | #2 |
Re: Intermediate Shaft Question
I believe the factory one is plastic. It's manufactured to shear if you are in an accident. That way you do have to have the full force of the steering column in your face.
If I was going with stock some type of aluminum or plastic screw may work. If you are going with a rack and pinion the funny angles required will likely collapse first. My 1957 column is like a fence post in front of my face. IMHO that is really dangerous in a front end collision. Anything you do will be better that that. Cheers |
10-28-2023, 07:48 AM | #3 |
The factory injected nylon in those shafts, much like some of the OEM universal joints in mid '70-s newer applications.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
10-28-2023, 08:39 AM | #4 |
Ok, thanks for the feedback. I wish one end of the nickel plated rod would have had a predrilled hole to insert pin through. Might be a pain drilling with a regular drill.
10-29-2023, 09:34 PM | #5 |
read up on your aftermarket column some are made to collapse on impact
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
10-30-2023, 07:30 AM | #6 |
I moved my steering column forward about 1¼" , so I had to take the intermediate shaft apart to shorten it.
The engagement of the two halves is fairly long so I didn't worry about trying to put anything back in the holes. There's no play in the joint when slid together. it's in a fixed position with the column clamped down and the rag joint fastened in, it's unlikely to come apart very easily and will still collapse in the event of a frontal impact.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
10-30-2023, 02:31 PM | #7 | |
